Oil & Fuel Oil Seal on TC55DA Front Axle.
   / Oil Seal on TC55DA Front Axle. #1
Osconda
Texas, Williamson County (aka Texas Hill Country)
New Holland TC55DA, delivered 05/25/2005
Hello Folks,
I have a very slow leak on the front left axle. Enough to accumulate a lot of dirt on the wheel between washings. I'm going to replace the seal but wanted to get some idea of what this job entailed.
Since it's front-wheel assist it looks like I have to pull the axle. Not sure though. I haven't taken anything off yet.
Anybody done this kind of repair before? Any advice? I should have everything I need in the shop except the seal ($55) which I haven't purchased yet.
   / Oil Seal on TC55DA Front Axle. #2
Hello Folks,
If it is the axle shaft seal leaking, it's quite straightforward. Have a tube of anaerobic gasket eliminator available to seal the reduction gear cover. Even the swivel seals aren't difficult. I routinely replace either on tractors on-site. Ford 10 and 20 series compacts and all the later NH compacts use the same designs, if not the same parts.
   / Oil Seal on TC55DA Front Axle. #3
Hi Rick B, When you say routine, are we talking 2 to 4 hours with the seal? Any special tools required?
Thanks, Coolhand
   / Oil Seal on TC55DA Front Axle. #4
A properly sized seal driver and a well stocked toolbox. Less than 2 hours for a first timer, less than an hour with practice.
   / Oil Seal on TC55DA Front Axle. #5
RickB - Thanks for the reply. Seal is on the way from Messicks. I have the seal driver - I looked at the assembly closely, seems pretty straightforward. Appreciate the info
Coolhand
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
