Who has the oldest/most hours on their Ch tractor?
   / Who has the oldest/most hours on their Ch tractor? #41
I've got around 700 on mine now. 354 kama
Just used it to set 3 acres of tobacco.
   / Who has the oldest/most hours on their Ch tractor? #42
Mitsubishi MT180D--use the FEL like it was a skidsteer, pry rocks with tooth bar and move/roll rocks bigger than the bucket.
Some issues but normal for what I do.
Can't complain, parts on costly side when needed but not a major issue so far.
Have about 1200 hours clocked to date.
   / Who has the oldest/most hours on their Ch tractor? #43
I've a '03 JM354 with no fel and have 980 hrs. do a lot of spraying, plowing,box blading,discing, bush hogging, tilling, planting, and areating, but not in that order. I have two grown daughters that keep it busy also. I just thought about it and I'm still on the original chinese batteries and ignition switch, both were said to be to cheap to work long, but mine are still going. I did replace alternator with a auto wrecking yard delco 10 si alternator $27. I'm going to need a new seat pretty soon though. I credit the not having a fel with not having many break downs, my two cents. bjr
   / Who has the oldest/most hours on their Ch tractor? #44
i know its been a while since the last post but i was curious about the hours on these tractors. I read this and had to point it out, a mitsubishi is a JAPANESE tractor.
   / Who has the oldest/most hours on their Ch tractor? #45
I am right around 600 hours, well actually 590ish. My tractor is a 2003 Jinma 254 and has been a work horse. Only a few minor issues like a starter that needed replaced and a few small things I broke, or helped along.
Chris
Well here is a update to my tractor. Its got 805 hours as of today. Gets 50 hour oil changes, 250 hour air/fuel/hydraulic filter changes and runs like a top. I did recently have a leaking front right seal on the axle. Ronald got me the parts and it was a easy 2 hour fix. Other than that all I have replaced was the starter mentioned prior, the battery, the thermostat, a few small items like bolts, light bulbs, ect.
I would buy again in a heart beat.
Chris
   / Who has the oldest/most hours on their Ch tractor? #47
Jinma 204 - now has 580 hours. Only issue has been an electrical short and a water pump. Would love more power but overall its been a great little tractor.
Mark
   / Who has the oldest/most hours on their Ch tractor? #48
My 2008, NorTrac 254 w/ FEL has 639hours. Runs great. Very regular service. It has served me and my neighbors well. I have forgotten it's only 25 horse, way too many times.Would, and will buy another one. Ronald has the next size up, I like. I will keep this one forever. When it gets tired. Rebuild!!:cool2:
   / Who has the oldest/most hours on their Ch tractor? #49
Our Foton FT404 tractor which is 14 months old has now 210h, with the backhoe mounted from 80h. Time for service with oil & filter changes now.
The tractor with the front end loader and the backhoe is a very useful combination, with a performance exceeding our expectations!
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53473)
2019 Ford F550...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
PRINTER (A53843)
PRINTER (A53843)
