Who has the oldest/most hours on their Ch tractor?
   / Who has the oldest/most hours on their Ch tractor? #41
I've got around 700 on mine now. 354 kama
Just used it to set 3 acres of tobacco.
   / Who has the oldest/most hours on their Ch tractor? #42
Mitsubishi MT180D--use the FEL like it was a skidsteer, pry rocks with tooth bar and move/roll rocks bigger than the bucket.
Some issues but normal for what I do.
Can't complain, parts on costly side when needed but not a major issue so far.
Have about 1200 hours clocked to date.
   / Who has the oldest/most hours on their Ch tractor? #43
I've a '03 JM354 with no fel and have 980 hrs. do a lot of spraying, plowing,box blading,discing, bush hogging, tilling, planting, and areating, but not in that order. I have two grown daughters that keep it busy also. I just thought about it and I'm still on the original chinese batteries and ignition switch, both were said to be to cheap to work long, but mine are still going. I did replace alternator with a auto wrecking yard delco 10 si alternator $27. I'm going to need a new seat pretty soon though. I credit the not having a fel with not having many break downs, my two cents. bjr
   / Who has the oldest/most hours on their Ch tractor? #44
i know its been a while since the last post but i was curious about the hours on these tractors. I read this and had to point it out, a mitsubishi is a JAPANESE tractor.
   / Who has the oldest/most hours on their Ch tractor? #45
I am right around 600 hours, well actually 590ish. My tractor is a 2003 Jinma 254 and has been a work horse. Only a few minor issues like a starter that needed replaced and a few small things I broke, or helped along.
Chris
Well here is a update to my tractor. Its got 805 hours as of today. Gets 50 hour oil changes, 250 hour air/fuel/hydraulic filter changes and runs like a top. I did recently have a leaking front right seal on the axle. Ronald got me the parts and it was a easy 2 hour fix. Other than that all I have replaced was the starter mentioned prior, the battery, the thermostat, a few small items like bolts, light bulbs, ect.
I would buy again in a heart beat.
Chris
   / Who has the oldest/most hours on their Ch tractor? #47
Jinma 204 - now has 580 hours. Only issue has been an electrical short and a water pump. Would love more power but overall its been a great little tractor.
Mark
   / Who has the oldest/most hours on their Ch tractor? #48
My 2008, NorTrac 254 w/ FEL has 639hours. Runs great. Very regular service. It has served me and my neighbors well. I have forgotten it's only 25 horse, way too many times.Would, and will buy another one. Ronald has the next size up, I like. I will keep this one forever. When it gets tired. Rebuild!!:cool2:
   / Who has the oldest/most hours on their Ch tractor? #49
Our Foton FT404 tractor which is 14 months old has now 210h, with the backhoe mounted from 80h. Time for service with oil & filter changes now.
The tractor with the front end loader and the backhoe is a very useful combination, with a performance exceeding our expectations!
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2002 Olympian Generator (A52377)
2002 Olympian...
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER W/FRUITLAND VACUUM PUMP (A53843)
2011 DRAGON...
