tractor tread tires for a riding lawn mower?
   / tractor tread tires for a riding lawn mower? #1
tpolley
i have a john deere saber 1742. i haven't double checked but i assume it's got 15x8 tires on the front and 20x8 tires on the back? do they make tires in this size with tractor tread? i can't stand those "turf saver" tires. they get stuck in wet grass. i've checked online and found nothing.
   / tractor tread tires for a riding lawn mower? #2
They make Ag style tires in a variety of sizes for lawn mowers. Verify what size you need and check with local tire shops. Tractor Supply Co. carries a lot of them around here as well.
   / tractor tread tires for a riding lawn mower? #3
I have seen them on Ebay for about $150/pair.
They just seemed a little too agressive.
   / tractor tread tires for a riding lawn mower? #4
Don't mow when the grass is wet!! :D
Actually, while aggressive tires are neat for certain situations they will tear up the yard. I had a set of Titan HD Field Trax tires on my X595 and they tore the heck out of the grass, so I went to regular rounded corner ag tires. Much better!! ;)
   / tractor tread tires for a riding lawn mower? #5
May have to change rims to match the AGs.
I did for the AGs I put on my WARDS MTD Lawn tractor.
my lawn mower says it's 20x8.0-8. which is which? is 20 the tire diameter? which is the wheel diameter and which is the tire/wwheel width?
   / tractor tread tires for a riding lawn mower? #7
20-tire height
8.0-tire width
8-rim size diameter
okay, one more question hopefully. i've found a source for the stile of tread i'm looking for. problem is they seem to have everything but the size i'm looking for. they have, 21x8.2-7.5 and 20.1x8.5-8.3 and so on. nobody seems to have a 20x8.0-8
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
28013 (A50322)
28013 (A50322)
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
Kawasaki NR (A50324)
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
