PT 425 Robin Engine-Power Trac Locked Up
   / PT 425 Robin Engine-Power Trac Locked Up #1
SCOTCHERS
Fallston , Maryland
PT-425
PT 425 with a robin engine. This weekend I went to start my Power trac and she started fine. I got off to load up the bucket and she started idling down and conched out.
No biggy. Started her back up and continued. Bogged down and stopped again,
I've, periodically, gotten debris in the gas tank cutting of the fuel and checked that. Nothing in there.
I blew out the gas line and all was unobstructed. Upon restarting, I turned the starter ignition and "1" click then what appeared to be a little crackle/sizzle. I stopped immediately and it appears my starter was under stress or dieing.
I'm also concerned maybe the motor could have locked up? I'm no mechanic, but can follow directions and have a basic understanding.
I'm planning on calling Terry this AM but thought I'd pick some brains.
My engine has approx 620 hours and has been maintained to the "T" I have left it out in the rain a couple times and this past month we've gotten a tremendous amount of rain. I live in MD My PT did get rained on for approx. 1 week. It's normally garage kept.
Thats all the info I know.
John, MD
   / PT 425 Robin Engine-Power Trac Locked Up #2
I spray down the engine compartment and the rest of the tractor at least once a week, and I have never had a problem. I think all the important stuff is more or less waterproof.
"click... crackle...sizzle" sounds like a drained or bad battery. Check the terminal voltage with a multi-tester, and then try to do it while you crank the battery to see how much it draws down the voltage.
Dying while running like you describe soundes like fuel starvation instead of a bad battery, but it could also die like that if your alternator is bad.
Ancedotal, I am sure, but I had a Dodge Dakota with an engine problem that plagued me... when it got warm, it wouldn't idle anymore. Very strange, couldn't solve it. And then one day (shortly thereafter) my battery died. New battery; no more idle problems.
2020 DRAGON ESP...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
