BX23 Alternator upgrade
   / BX23 Alternator upgrade #1
creex
Middle TN
BX23
Could someone that has done the alternator upgrade check the new one for a Denso/Hitachi/Etc. number so it could be cross-referenced? I would like to do the upgrade, but with a job on hiatus, looking to save a little.
   / BX23 Alternator upgrade #2
do a search and check out escavader thread on his upgrade. He did the upgrade himself but ended up with problems due to a bad wire harness and had to be replaced. he eventually got it working.
   / BX23 Alternator upgrade #3
You cant get by with just an alternator,youll need a whole new wiring kit.The original dynamo has electrics up under the dash to un hook,and rewire ,The new alternator needs different mounting bracketts also.All this would be a real pain without the kit.
Ididnt have a bad harness,i had a defective fuse from the factory.Thats another thing the fuse on the new wiring is much larger than the original.
ALAN
   / BX23 Alternator upgrade #4
ALAN
Overall Alan, was the upgrade worth it? Asking because I'm thinking about it too...Thanks.
Don
   / BX23 Alternator upgrade #5
Why do you need more electrical power? Do the BX23's have a 40amp alternator?
   / BX23 Alternator upgrade #6
If you need more amps to add more lights on bx23- you need to upgrade the alt. it has a dynamo alternator. escavader- thanks for correcting me though- glad it was a defective fuse
   / BX23 Alternator upgrade #7
Isn't the whole kit about $200 through Kubota Whole Goods(your salesman)?Seems like an easier way to get it right the first time!
   / BX23 Alternator upgrade #9
Don
ABSOLUTELY!! I never worry about what im running any more.Ihave the heater on high,two forward floods .two rear floods ,revolving light on top,circulating fan,cell phone charging and sone a sound system
ALAN
   / BX23 Alternator upgrade #10
Yes ,you are correct.You can buy a replacement ,to replace the one in your kit,but its more than the kit itself
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
8065 (A55852)
8065 (A55852)
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60460)
1990 Lufkin...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
