98.5-02 dodge ram door lock trick
   / 98.5-02 dodge ram door lock trick
Thanks for the link there is 26 pages on this issue I guess it will take all night to read it!
by by
tom
lucky your running an 06, if you had a vp44 issue and needed the knowledge on that site it can take a month. lol
   / 98.5-02 dodge ram door lock trick #12
The dealer said it would be 1/2 hr charge for each item the program just tell me what you want it.
Wow thats crazy mark up in my opinion. Programing 5 things would take about 10 minutes if they know what their doing.
One programing note , everone know that if you flip the key 3 times leave it on the 3rd time it has a brief code display like odb trouble codes. Ive never seen anything valuable thou only companion codes.
   / 98.5-02 dodge ram door lock trick #14
The lock trick is also covered in the owners manual. JC
   / 98.5-02 dodge ram door lock trick #15
I tried turning off the horn beep when locking the truck on my 07 Ram. No matter how hard I try, it won't work. Either it doesn't work the way it's says i the owners manual or I'm an idiot.
   / 98.5-02 dodge ram door lock trick #16
Are you using the remote for the very last step ?
Don't laugh, I didn't.
   / 98.5-02 dodge ram door lock trick #17
Thanks Will, I'll try that. It's been several months ago that I tried it, so I can't remember the process at all, but when I read it again, I bet your suggestion makes sense.
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2015 Peterbilt 567 Wet Kit T/A Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
