Cleaning out barn
   / Cleaning out barn #1
Conservation
Will it ever end? I have a pole building with 2/3rds of it being dirt floor. Or should I say poop floor? Last owner had horses. I am using a box blade to pull the old, compacted poop out. My question is, how do I know when to stop? The poop just keeps on coming. I can tell where the concrete level is, so I can level up the gravel with that. I want to store trailers and equipment in there in the future to keep them out of the weather.
It's been 4 years since a horse stood there, but today it smells just like they were there yesterday!
   / Cleaning out barn #2
Don't you have a FEL ?
   / Cleaning out barn #3
Been there, done that. Just keep digging. Keep in mind you may never ever get the urine smell out. . . . :p
good luck!
   / Cleaning out barn #4
Can you get under it and lift up "chunks?" I did the same at my last place. I was also lucky enough to find where he buried a few dead goats...I was wishing for just urine smell about then! But you do want all that poop out so you can have a stable base for concrete in the future.
Peter
   / Cleaning out barn
Thanks for the replys. I do have an FEL, but the stuff is so compacted that the FEL just won't cut it. If I had a tooth bar, it would probably be more effective. What stinks (LOL) about the box blade is that the poop compacts in there so tight that I have to get off and help it out with a shovel every drag. I am using a bunch of weights on the box blade to get it to dig in, but the scarifiers are not needed for this job.
This is just going to be a shed for storage, not a shop. So a gravel base is fine for this. But, I don't want to put the motorhome in there and have it come out smelling like poop or urine!
Burried goats?! Yikes!
I still need to get a couple stantions out of there, and next year I plan on putting a big door on the short end so I can get big stuff in and out.
Sounds like I just need to keep going for a bit. The gravel I tend to use has a lot of fines, and packs well. That should help, but I wouldn't count on it totally cutting the smell. Funny that it really didn't smell until I disturbed it! I am letting it dry out a couple of days before going back at it. I have a pretty big pile of poop going outside. I drag it out with the box, then pile it with the FEL.
   / Cleaning out barn #6
Sounds like a set of forks on your FEL would work pretty well, if nothing else you could break it up with the forks. I put down powdered lime to rid the smell of horse urine in the stalls.
   / Cleaning out barn #7
Have you tried backing a disc in there and pulling it out with some weight on it?
   / Cleaning out barn
Well, no but....I pulled some more out today, and I am getting down to the last of the wet dirt. There were some very bad smells from time to time, and I am no stranger to the barnyard! I think I will clean up the edges by hand, since I don't have a helper to watch, and I am chicken with the bucket. I am within 8" now. I need to get a friend's stuff out of the other side and pull some posts and get that area cleaned up too! Then gravel!
   / Cleaning out barn #9
I beleive I would sanitize the area with a few bags of barn lime before your base is placed.
   / Cleaning out barn
Where do you get the lime?
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
