trailer help
   / trailer help #11
I balance every set of tire that goes on a trailer. I usually have to argue with the tire guy because they say its not necessary on trailers but I can tell you it makes a difference.
Chris
   / trailer help #12
Horses can also tell the difference, their legs and feet don't like riding for hours on unbalanced tires.
   / trailer help #13
I agree with the balancing of trailer tires. I would think that all tires would benefit from being balanced. The guys at my tire shop think the same way. Why?? It don't help trailer tires. I almost want to tell them if they don't want to balance them then I will go somewhere else.
   / trailer help #14
Beyond balancing, when was the last time that you saw a "tire jockey" torque your lug nuts to spec? Hammer at it with the air gun until it sounds about right seems to be the norm.
   / trailer help #15
I recently had my OEM truck tires rotated at Discount Tire, and I was shocked to see the guy grab a torque wrench and torque all 24 lug nuts to the factory spec. That was my first time dealing with Discount Tire, and odds are good that I'll be going back when I need tires (soon---lousy OE Goodyears). FWIW, there was also no charge for the rotation, even though the tires are factory originals.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
24in pin on excavator tooth bucket (A56438)
24in pin on...
Towable Dewatering Pump (A59228)
Towable Dewatering...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
