HANGOVER MOWER .
   / HANGOVER MOWER . #11
Here is another boom type mower, and I believe it is a flail. can use it in all positions.
   / HANGOVER MOWER . #12
Tiger has lots of side mounted flail mowers and boom flail mower mounted off either the side or rear. I believe they have rotary mowers as well. I'm thinking of a 8' rear flail coupled with a 4' side mounted flail for whenever I get my 30 acre chestnut orchard installed in a couple of years.
   / HANGOVER MOWER . #13
Would a three point or FEL mounted boom pole running to the side with an old gas power push mower hung on it work the the area you want to mow?
   / HANGOVER MOWER .
Yeah about or something like I had in mind; but I've never seen anyone on here or any place else build one.
Anybody here built one ?
   / HANGOVER MOWER . #16
One of the guys in Power-Trac built one , I will see if I can find a picture.
   / HANGOVER MOWER . #17
check on youtube there one on a crane mowing a pond and its a zturn
   / HANGOVER MOWER . #18
Here is a lawn mower mounted on a boom pole.
   / HANGOVER MOWER . #19
Now, that's good. This sparks me an idea of adding electric boom mower drived by tractor electricity. Will be much simpler than pto driven mowers which cause the mowers complicated and expensive.
   / HANGOVER MOWER .
Now, that's good.
This gives me the idea to add an electric boom mower drived by tractor electricity.
Will be much simpler than pto driven mowers which makes those mowers complicated and expensive.
I'm thinking of a combo that could be attached to a 3 point or a fel or operated as a pull behind either rite behind the tractor or off set.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
405 (A52706)
405 (A52706)
Booster Cables (A59230)
Booster Cables...
(APPROX. 20) 4' X...
