Kioti oil specs API: CC or CD~ Amsoil Diesel OK?
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
I've read the owner's manual for my Kioti DK35se/hst and the book says: API rating CC or CD?!
I cannot find any diesel oil that says it meets those spec letters; there are higher letters in the alphabet but I don't know how the companies/API determines their rating system lettering.
My main question is: does Amsoil's synthetic 15-40 Diesel oil meet or exceed the CC or CD specs?
If so, are a lot of you guys using it in your newer, or for that matter older tractors, and what are your thoughts on it vs. Rotella T synthetic or other similar or different synthetic oils?
Thanks,
CM
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #2
Thanks,
CM
Yes, it will work great in your tractor. I used to run Amsoil's synthetic 15-40 in my machines but it just got too danged expensive. I think I have Delvac and some Rotella on the shelves now. I feel that the Amsoil is a superior oil by a wide margin, but I can't see having a problem using Delvac or Rotella as long as you keep up with normal maintenance. If I used my machines extremely hard and/or planned on putting over 10k hours on them, I'd likely stick with Amsoil; but I don't so I won't. :)
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #3
Rotella oils are more than adequate for your Kioti; I use Rotella 5W40 synthetic in my 3054 for it's low temp pour qualities for low temp starts. The "cc,cd" specs have been superceded by the higher speced "cf's"etc;the later(higher) the alphabetic letter, the more recent and superior the rating. Seeing as your in Vermont, you need the same low temp performance.If I lived in a warmer climate, I'd use the less expensive "dino" oils available ;)
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #4
I wonder how fast the specs change? Our MF 1523 manual calls for the same thing.
Thanks guys!:D I appreciate and value your input!
I figured the later letters superseded the earlier ones but there was no way to be sure...
Since I live in VT I agree with Patches assessment; however the tractor will be moving into its newly constructed, heated floors barn before winter so I figure the 15-40 should do it?
Agreed? Other opinions on the 5-40 vs. 15-40 for cold climate?
P.S. I do have a block heater too in case it needs to stay outside overnight in the cold....
Thanks...
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #6
Those API Specs are outdated. Look for CH-4 or CI rated oil these days to be compatible with the ULSD.
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #7
Is CG compatible with ULSD?? 10W30 syn diesel oil is hard to find. 5w40 is not though.
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #8
I am using amsoil AME 15W-40 in my CK25 the cost really is not that high if you are buying more then 1 quart at a time. I also use ACD 10W-30/SAE30, both are great oils that are CI-4+ rated. AME has a 40C better then some 5W-40's and a low pour point thats tough to beat. It will flow even in cold temperatures. I stick with AME or ACD myself rather then the newer CJ-4 rated oils for my tractor.
That said Rotella T is a proven oil that is very, very good as well. I can buy either locally so it would be a coin flip for me unless I was shopping at walmart. I would use either with confidence or as mentioned already Delvac.
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #9
from a quick google search revealed that CC was in place prior to 1990 - CF came in 1990 or so..
birna
   / Kioti oil specs API: CC or CD~ Amsoil Diesel OK? #10
Thanks...
Go with the 5W40, your valve train will love you for it.
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2010 Dodge Grand Caravan (A50324)
2010 Dodge Grand...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
