Rental attachments
   / Rental attachments #1
vrman
Joliet, IL
Kubota BX23 & ZD326P
Has anyone ever rented a post hole digger to use with their BX23? Just wondering if I should look for a specific brand that would work best. Only have a few holes to put in for a deck, and didn't want to buy one for myself.
Thanks!!
   / Rental attachments #2
Who you rent from may not understand sub compact tractor. The BX's will not use most post hole diggers. There is a Lienbach Jr for BX's, I'm not recommending it I'm just saying it is supposed to fit the BX's.
   / Rental attachments #3
Thanks!!
For just a few holes I would not remove the BH to hook up a post hole digger.
I'd just dig the holes with the BH .
   / Rental attachments #4
Depending on your ground, you could also rent a self contained post hole digger with small gas engine for one or two operators to use.
   / Rental attachments #5
The standard Leinbach's work on a BX, with a "standard" length auger, whatever that is. I never actually measured the one that I used, but it came with the auger. (Which I subsequently mangled, and will be buying my buddy a new one.)
It does barely clear the ground when travelling though.
For only a few holes, you want to use an implement instead of doing it with a manual post-hole digger? I'd like to say that I don't understand that line of thinking, but I can't... :)
Jesse
Ha! Well, I had a secondary goal too....wanted to see if it would be worth it to pick one up eventually. You know, to add to the "collection" of toys!
Problem is, I need to put the holes in specific areas, without damaging the concrete around it. Otherwise, I'd be in there with the BH, trust me! :)
I've never used the motorized hand augers before. I don't know how good they are for going down 4-5 feet and 8-12" in diameter. They always looked kinda dangerous to me.
   / Rental attachments #7
Looks like you know what you need and have evaluated your choices logically. Just remember to make sure the one you rent will fit the BX. The one man or 2 man hand operated motor on top can be extremely dangerous. I saw 2 men operating one once and it would sling them all over the place when they would hit a rock or a really hard piece of clay and theirs was not 8" to 12" auger. Rent one for your tractor.
   / Rental attachments #8
I think the longest auger (and still be able to drive around with) that you can mount to a BX23 is 48" in length with only 42" of usable depth. If you must go at least 4' down, you will have to finish each hole by hand.
   / Rental attachments #9
I rented a bobcat with a posthole digger mounted on the front. After using that, it's hard to ever go back to a 3PT digger. You can push down with the hydraulics, so you can punch a hole and be done before a 3PT digger has even gotten started. It's also much easier to see what you're doing and don't have to twist your body around like a pretzel to see what's going on behind you.
   / Rental attachments #10
I completely agree with Mark, a rented skidloader would be perfect. 3pt augers are good for fence posts, but a hole that big would be kinda tough on an AG, let alone a BX.
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
