Lasting Non-toxic Fence Posts..Do They Exist?
   / Lasting Non-toxic Fence Posts..Do They Exist? #32
casted concrete posts
+1
(and more text hear because i guess just +1 isnt enough of a message to post for some stupid reason)
   / Lasting Non-toxic Fence Posts..Do They Exist? #33
   / Lasting Non-toxic Fence Posts..Do They Exist? #35
Concrete posts are not hard to make.
1. Cut a plastic pipe in half lengthwise.
2. Reassemble with hose clamps.
3. Plug the bottom end with a wooden plug with holes to hold rebar
4. Fill with concrete
5. Rod with a spare length of rebar to remove trapped air. (alternatively smack form with a hammer or vibrate it B_U_T don't get carried away as you don't want to separate out the aggregate from the mix.
6. Cap the top hole with a holed cap to hold the rebar in position.
Some additional thoughts:
1. Add a plasticizer water reducer to the mix to get a very mobile easy flowing mix without having to add extra water which will lower the strength.
2. Keep the rebar two or more inches from the outside of the form. (if you overlap/splice rebar overlap it at least 25 times the diameter of the rebar)
3. Don't put rebar near the center of the assy as that rebar will hardly do anything for strength/stiffness (bending resistance) Three or four rebar in triangular or square pattern is good. rebar position can be maintained by tieing with stiff wire.
4. Do the math... this is a 6 inch or larger diameter post.
5. you can put waterproofer in the mix if you want the post to last for your grandkids grandkids.
6. You can bore holes in the forms (right angles to long axis) and insert smaller plastic pipe to accept cables, sucker rods, barbed wire or ... if you want really neat appearance.
After the mix sets up sufficiently to not be harmed by removing the forms you remove the hose clamps and peel off the plastic pipe to reuse over and over.
Oh, the little pipes to make wire ways through the posts... they need to be split lengthwise on one side, not cut in two like the big pipe. They can be driven out of the post with a drift and a hammer and reused.
Another nice touch is to add concrete dye to the mix and get a much better looking post.
Pat
Great Post. and posts.
My father in law built his own concrete post about 40 years ago and they are still going strong. Here is what I think are his instructions, but I am liking your scheme as well. I still have the forms he used in my shed but haven't taken on building any yet.
  • Concrete Post0002.PDF
   / Lasting Non-toxic Fence Posts..Do They Exist? #36
Certainly others on here have heard of or seen a ripgut fence. Everytime I attempt to bring up a link to articles, I am thwarted by some cyberghost. On my desk is a copy of The Mother Earth News, March/April, 1980, page 116. This article is listed on the web at The Mother Earth News, but the link is broken, as are a most others listed on Google.
If you have access to the materials, this could be the answer to anyone with unfriendly digging conditons, or concerns about soil contamination from treated posts.
   / Lasting Non-toxic Fence Posts..Do They Exist? #37
Here in the S.E. the DOT is replacing all the wildlife fencing along the Interstate highways...They are upgrading from 6' (I think) to 10' (I think)...I am not sure if this is happening only in the south or not...If they are doing the same thing in your area you might check with whoever is supplying the DOT for a source...I am fairly certain they are using galvanized pipe stock/caps
   / Lasting Non-toxic Fence Posts..Do They Exist? #38
didn't the OP want an 8 foot high deer fence? that would mean about 12 foot posts w/ four in the ground. is that really practical w/ concrete? i mean you would need to place each pole with hydraulics as they would weigh well over 300 lbs each.
amp
   / Lasting Non-toxic Fence Posts..Do They Exist? #39
"Deer Proofing Your Yard and Garden" by Rhonda Massingham Hart.
Second Addition.
Pat
   / Lasting Non-toxic Fence Posts..Do They Exist? #40
I think I'll start planting some Catalpa and Black Locust trees. Maybe my daughter could sell them as a side line of work.
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 42-6FGCU25...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
