2002 F250 Diesel Problem...Hurry!!
   / 2002 F250 Diesel Problem...Hurry!! #11
Glad you got it up and running again.
Chris
   / 2002 F250 Diesel Problem...Hurry!! #12
Which fuse?
   / 2002 F250 Diesel Problem...Hurry!! #13
Very common issue. I have a 01 and if you turn the OD off then back on it will pop the fuse everytime. I really need to put a little tape around the wire.You need to pull the ignition and then the colum covers will come off. There is a great write-up over on TTT.Thedieselstop.com
   / 2002 F250 Diesel Problem...Hurry!! #14
Which fuse?
that would have been my first question. sounded like it was a fuse problem to start with. put fuse in, blows, put second fuse in, blows.... = problem with wireing
Which fuse?
They said it was #42 but I did some checking when I got the truck home and I believe you were right that it was #41.
   / 2002 F250 Diesel Problem...Hurry!! #16
I know you said you checked all the fuses and sometimes it's hard to tell if it's poped or not so I use a 12v test light to check fuses, it's faster and tells if you got pwr or not on both sides.
   / 2002 F250 Diesel Problem...Hurry!! #17
I had the same problem with my truck and I got news from a friend that worked for ford before the recall was issued and I ended up replacing the CPS and the problem was fixed. I haven't had any fuse problems as of yet.....Knock on wood!!! Love the truck though!
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
EINGP PHT620 HAND PUSH ELECTRIC FORKLIFT (A57192)
EINGP PHT620 HAND...
2018 Bobcat T750 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T750...
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
UNUSED FUTURE MINI EXCAVATOR QUICK COUPLER (A57193)
UNUSED FUTURE MINI...
UNUSED 1RANCH 1RGPM GROUND PROTECTION MATS (A57193)
UNUSED 1RANCH...
