What attachments did you THINK you needed but don't use much?
   / What attachments did you THINK you needed but don't use much? #81
#1 disaster was my attempt at a potato plow based on a design out of a tractor book. It wouldn't even break the ground with my tractor.
#2 disaster was one of those quick hitch things that didn't fit any of my implements without modifications.
#3 disaster-- built gauge wheels for a sliding 6' grader blade, but couldn't get the grader blade to reliably lock into position.
I can't achieve the same results with the FEL as the rear box blade. I've seen guys grade with the bucket on a bobcat and get good results, but not me for whatever reason. I get more done with my rear box blade, bush hog and plow than anything else.
   / What attachments did you THINK you needed but don't use much? #82
   / What attachments did you THINK you needed but don't use much? #83
Off Topic -
How come some responders like Lbrown and jas67 seem to require many separate posts in a row, while others like archerm3 can wrap up replies to 4 posts in 1?
Do some people get paid for posts?
Is there some honor in wasted bandwidth?
I thot it was just a parody of LBrown
larry
   / What attachments did you THINK you needed but don't use much? #84
   / What attachments did you THINK you needed but don't use much? #85
I think that LBrown does. Look at the number of posts that he has.
Wow!... Great idea...And I thot it was just a parody of LBrown. ;)
larry
   / What attachments did you THINK you needed but don't use much? #86
   / What attachments did you THINK you needed but don't use much? #88
my fel and box blade are invaluable for my use. They complement each other as they do different work.
I had to have a quick change system and purchased the one at the top of home page. Its for sale now. With 7 different attachments and their different pin widths I can hook/unhook quicker with out it.
   / What attachments did you THINK you needed but don't use much? #89
I have some questions for you guys that prefer your FEL to a box blade. What type of grading are you doing with your FEL? What do you do when you need one side lower than the other? :confused:
Let some air out of the tires on one side? ;)
   / What attachments did you THINK you needed but don't use much? #90
Off Topic -
*How come some responders like Lbrown and jas67 seem to require many separate posts in a row, while others like archerm3 can wrap up replies to 4 posts in 1?
4 Me.
*Depents on when and or how I schedule posting.
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
Hustler super Z zero turn (A56859)
Hustler super Z...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
