What attachments did you THINK you needed but don't use much?
   / What attachments did you THINK you needed but don't use much? #81
#1 disaster was my attempt at a potato plow based on a design out of a tractor book. It wouldn't even break the ground with my tractor.
#2 disaster was one of those quick hitch things that didn't fit any of my implements without modifications.
#3 disaster-- built gauge wheels for a sliding 6' grader blade, but couldn't get the grader blade to reliably lock into position.
I can't achieve the same results with the FEL as the rear box blade. I've seen guys grade with the bucket on a bobcat and get good results, but not me for whatever reason. I get more done with my rear box blade, bush hog and plow than anything else.
   / What attachments did you THINK you needed but don't use much? #82
   / What attachments did you THINK you needed but don't use much? #83
Off Topic -
How come some responders like Lbrown and jas67 seem to require many separate posts in a row, while others like archerm3 can wrap up replies to 4 posts in 1?
Do some people get paid for posts?
Is there some honor in wasted bandwidth?
I thot it was just a parody of LBrown
larry
   / What attachments did you THINK you needed but don't use much? #84
   / What attachments did you THINK you needed but don't use much? #85
I think that LBrown does. Look at the number of posts that he has.
Wow!... Great idea...And I thot it was just a parody of LBrown. ;)
larry
   / What attachments did you THINK you needed but don't use much? #86
   / What attachments did you THINK you needed but don't use much? #88
my fel and box blade are invaluable for my use. They complement each other as they do different work.
I had to have a quick change system and purchased the one at the top of home page. Its for sale now. With 7 different attachments and their different pin widths I can hook/unhook quicker with out it.
   / What attachments did you THINK you needed but don't use much? #89
I have some questions for you guys that prefer your FEL to a box blade. What type of grading are you doing with your FEL? What do you do when you need one side lower than the other? :confused:
Let some air out of the tires on one side? ;)
   / What attachments did you THINK you needed but don't use much? #90
Off Topic -
*How come some responders like Lbrown and jas67 seem to require many separate posts in a row, while others like archerm3 can wrap up replies to 4 posts in 1?
4 Me.
*Depents on when and or how I schedule posting.
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2004 Toyota Camry Sedan (A59231)
2004 Toyota Camry...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
