ford 1920 clutch problem
   / ford 1920 clutch problem #1
Lazy
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
I got on the tractor today and started it and let it warm up for a few minutes, pushed the clutch in and started to put in gear and heard the gears grind:mad: I can't get the clutch to release the engine from the transmission so I can put it into gear. Is this going to be a dealer fix, or is there a trick to fixing this problem? Any help would be appreciated.
unlucky me:mad:
   / ford 1920 clutch problem #2
Lazy, your clutch disk has rusted to the flywheel. If you do a search for rusted clutches you will find various ways to try to free it. If you do get it to free up make sure when you park it you block the petal in the down position
Bill
   / ford 1920 clutch problem #3
Lazy,
Ditto on what Bill said. A high tech piece of 2x4 is all you need to keep clutch disk a bit separated from flywheel so they won't rust together.
JC,
Thanks for the replies. I hope thats the problem, I checked the price of the clutch disk and they were approx 300 dollars. a complete dual clutch assembly is like 2000 dollars.
What do you guys think of this Idea for freeing the clutch, raise the rear wheels off of the ground with the backhoes outriggers, bypass the neutral start switch and start the tractor in gear then shift into neutral and while the rear wheels are spinning use the brake to see if the sudden stop or shock will free it up?
Performed the task in my last post while holding the clutch down with the tractor in reverse hit the brake a few times and it fixed the problem. I now am a happy camper,:D:D:D:D I hope this post will help someone else in the future.
   / ford 1920 clutch problem #6
Glad you got it freed up. Also check the drain in the bottom of the belhousing to make shure its not pluged.
Bill
   / ford 1920 clutch problem #7
the 1920 came with a lil wedge of wood on a string back in the tool box for blocking the clutch.. see if yours is still there.. if not.. make one.
soundguy
   / ford 1920 clutch problem #8
Well, I understand the function of the block of would. But how long can it sit before you would need to use it? A day, week, month?
Stuart
   / ford 1920 clutch problem #9
Stuart
It actually has more to do with humidity rather than time. When the tractor is being left unused for longer periods of time, weeks vs days, use the block as a preventive. This condition first reared its head a few dacades ago in European seaports - rather humid conditions with salt exacerbating the condition.
   / ford 1920 clutch problem #10
I've also found that once one sticks once.. it will 'like' to stick more often.
soundguy
   / ford 1920 clutch problem #11
Soundguy, you are so right about it having a tendency to do it again. Yesterday I had to break the clutch free for the 3rd time in 7 years. (My son used the tractor last and didn't know about blocking the clutch.) Usually I only have to put it in low range and go into the gravel bank to break it free, but this time I had to use 4wd and go against a tree to break it loose. I am putting a small dash plaque as a reminder to block the clutch. Bill C
   / ford 1920 clutch problem #12
Yep.. like I said.. i've got 2 tractors that will stick then if I don't block them.. guaranteed.
soundguy
   / ford 1920 clutch problem #13
soundguy
You're quite right about that. The friction material can contribute also, particularly if it has the ability to absorb any moisture. Over the years we've seen a variety of friction materials including everything from cerrometallic to walnut shells. The higher moisture areas are more prone but no one seems to be immune.
   / ford 1920 clutch problem #14
I also have a 1920 and although I have not had the clutch stick like you describe above, I sometime have problems getting it into gear. This is while I'm working, moving from 2 or 3 into reverse and back again. It does not happen all the time, but enough to be aggravating. I've adusted the clutch pedal to specs, but does not help. Could this be related to the lock up problem, because I've never used the block? Any ideas?
Thanks.
   / ford 1920 clutch problem #15
Thanks.
Clutch disk sticking should follow after some storage period. I wondered why it should do it while operating specially the fact you have adjusted the pedal free play specs and it happens randomly. Does it happen at certain rpm?
JC,
   / ford 1920 clutch problem #16
No, no certain rpm or even rpm range. It does it at idle or any rpm. It acts as though the clutch is not completely disengaged. If it won't go into 2nd from reverse, I can go to 3rd, release the clutch and then go to 2nd. I am wondering if the clutch is not completely disengaging and if I ignored the specs and adjusted the pedal accordingly. Would this cause more problems?
Thanks.
   / ford 1920 clutch problem #17
I'd try double clutching.. though the fact that you can select another range seems normal, then you can slip her into the correct gear.. etc. I've got plenty of tractors with crash boxes that you can double clutch to get a gear if it won't take it straight over.. or select another gear first to perhaps get something aligned.. then select your gear... I don't see that as a big issue..
soundguy
   / ford 1920 clutch problem #18
Thanks.
clutch pedal free play adjustment externally is translated internally to distance between the release bearing surface and the pressure plate fingers. They should be close but not touching. If the distance is too much, you press the pedal all the way and you release the disk partially and that is not good. Maybe this is your problem. That causes erratic gear engagement and disk wear. On the flip side if the release bearing is too close to the fingers , then your are able to completely disengage the disk but you run a chance of riding the clutch and premature wear of pressure plate fingers, release bearing or both. Double clutching to find the sweet spot works but I think correct adjustment is a better alternative in the long run.
JC,
   / ford 1920 clutch problem #19
I've seens plenty of machines that were just finicky.. adjusted correctly.. but liked that double clutch.. or another gear to get them synchronized. etc.. then again.. I'm used to them old crashbox ford trans that farmers use for 50 years and when you buy it and drain it, 3 quarts water comes out.. a dead rat.. some metal chips. and alil oil floating n top.. ;) .. then you dump some diesel thru, let it drain.. refill with oil, and go another couple decades! ;)
soundguy
   / ford 1920 clutch problem #20
Thanks.
My 1910 has no problem shifting from gear to another or to reverse, but If you put it in neutral and then back to a gear it acts as though the clutch was not disengaging. I usually idle way down and then shift to 1st and then to the gear I want to use. It goes to 1st with the least grinding. It's been this way since new. I think finicky is the right word.
It sits up to three weeks without clutch blocking in a building. In the winter when it sits longer I block the clutch and put a float charger on it. This has been one terrific tractor.
CAT 930M (A58214)
CAT 930M (A58214)
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Attention (A57148)
Attention (A57148)
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
