Hydraulic Fluid Level Too High. Problem?
   / Hydraulic Fluid Level Too High. Problem? #1
Dr. Bob
Sergentsville, NJ (Western NJ, the good part!)
2003 B7800
I just did the 300 hr service on my B7800. When filling the hydro fluid, I overfilled it by quite a bit; not running out of the fill hole, but over the max level on the dip stick by about an inch.
Is this a problem? If so, what is the best way to drain the excess fluid and catch it for re-use? If it is a problem, what are the problems it can cause?
   / Hydraulic Fluid Level Too High. Problem? #2
My thought would be that it would take 5 minutes to drain a little bit out of the drain hole to get it within the manufacturer's recommendation. Honestly, even if someone on here told me it was OK to be an inch over I'd get it right because it's me that would be fixing (or paying) if something happened down the road. Five minutes of time for peace of mind?
   / Hydraulic Fluid Level Too High. Problem? #5
I have my BX overfull by a quart and it has caused no problem. The hydro has a breather and none has come out. My thot is that since there are no reciprocating parts of any significant size there isnt an issue of pressure fluctuations to cause damage to seals. I may try to suck a bit out one of these days if I get time, but it seems a non issue.
larry
   / Hydraulic Fluid Level Too High. Problem? #6
I'd just D and D it.
Transulation
Drain
Dump
   / Hydraulic Fluid Level Too High. Problem? #7
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED TRAILER (A54607)
2025 GREAT DANE...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2838 (A54757)
2838 (A54757)
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
