Round Bale Size - What do people have their set at?
   / Round Bale Size - What do people have their set at? #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I have a JD 467 baler. I am running it at 65" bale - JD guy recommended that. These bales are for my consumption. I am thinking maybe I should bump it up.
Comments?
D.
   / Round Bale Size - What do people have their set at? #2
Bale size for 'home use' should be decided with the following in mind:
The capacity of the equipment you will be handling the bales with.
How the bales will fit in your storage.
The size of any feeders you have.
Will the animals consume a bale before weather spoils part of a bale?
The convenience of handling fewer larger bales.
It hardly matters what other folks are doing.
All good points.
I was wondering from how the baler would handle it.
I am going to go weigh a load of bales when I haul these out of the pasture to see how much they really weigh.
Thanks,
D.
   / Round Bale Size - What do people have their set at? #4
I currently run my monitor on 68" and end up making about a 70" bale with the lag time between the monitor, sensors and me getting stopped. I started out last year on 70" but my baler will not wrap bales if they top 73" and that happened a couple of times in heavy hay. A friend of mine with a new JD467 runs his on 65" like you do per JD's recommendations.
Quite a few of the custom operators here run their 5x6 balers on 60" making a 5x5 instead of a 5x6.
I am running a JD 5525 tractor which is 75hp PTO. I wonder how much bigger a bale it will turn without any headaches. I have not had any problems yet, but I suspect I might be somewhat marginal if I went too much bigger.
D.
   / Round Bale Size - What do people have their set at? #6
I make a 5 x 5 1/2 bale with my JD 535 baler. My 85hp JD 6400 doesn't even change sounds from an empty baler to a full bale. The hay is for my own use so I make the rolls almost as big as possible. Less hay to handle, rolls last longer when I feed.
   / Round Bale Size - What do people have their set at? #7
My Vermeer 604K is all manual, but I try to make a 6 foot bale.
   / Round Bale Size - What do people have their set at? #8
My baler is supposed to be set at maximum to make a 5' wide and 6' diameter bale, but I haven't seen any bales out of it as tall as I am, and I am 6' tall. :confused:
I measured mine when I first got it and the numbers were pretty close. I am thinking I will bump up the size of my bales to increase how much actual hay I can shove in my storage areas.
D.
   / Round Bale Size - What do people have their set at? #10
There can be several reasons for that. The most simple being the pointer or if you have a monitor and electronics that the height setting is out of adjustment. The Vermeer 504 Super I that I had several years ago needed the bale size calibration checked at least every year. Another common problem is if the bales are not tight enough they will squat excessively.
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51247)
2012 VOLVO DBL...
Hustler Raptor SD Zero Turn Mower (A51573)
Hustler Raptor SD...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
