buckle97
The speed sensor is located in the overdrive gear case.
Thanks for the pics and explanation. I'll let you know what I find out.
Buckle, I don't believe you mentioned that before.... but regardless, I urge caution depending on tha results of and Autozone test... there are various grades of testers and they use the cheap ones... it's been my experience that they invaribl point to the oxy. sensor... trouble is, those things can be pricy and there are more than one on most vehicles.. Okidokers?
Cheap or expensive scan tools do the same thing. they read the codes set in the computer. a real cheap on may just give you a number you look up; a slightly higher priced one would give you the code description. expensive ones let you access extra diag features.
a code is saying to you the car is sick. Proper diag tells you what is wrong
System lean bank 1 (p0171), COULD be a bad MAF sensor, bad o2 sensor, or if its a ford a intake leak-
Don't judge the scan tool, judge the operator. What training does autozone give to guys to read a code?
Hope this helps give you a little more info in trying to decide what to do.
If you would get a newer used truck, what would you do with your current truck? Just saying that if you would trade it in or sell it out right, then you would most likely have to get it fixed anyways.
so what did you get for 200.00? Im thinking a little more than just a code read, 8-9 years ago i doubt the labor rate was 200.00 an hour.
I got a code read and the advice that "if it happens again, bring it back".
I bought the code reader so I could ignore that advice.
