Oil & Fuel 2015 4WD Oil Leak
   / 2015 4WD Oil Leak #1
Charlie175
Gold Member
Virginia
Mahindra 2015 gear
I was finish mowing today and finished the yard and lifted the rear deck (3 point) and backed up, I then noticed an oil stream on the ground and immediately shut down the tractor. The oil is leaking from the top of the transmission. I restarted the tractor and no leak until I lifted the 3 point and oil ran down from the top. Maybe a pop valve or hose busted.
From the looks of it I will need to remove the seat and seat support to see what is wrong, maybe even the fenders as it seems they are held on by the same support.
Any ideas on what went wrong?
   / 2015 4WD Oil Leak #2
It may be a loose bolt on the banjo fitting to the left of the seat under the sheetmetal. I have seen this happen before.
   / 2015 4WD Oil Leak #3
Happened to me on my 2615. It was an easy fix. A little startling at the time when the oil came squirting out.
   / 2015 4WD Oil Leak
By golly you gents were correct!
That sucker was ready to come off
Thanks for the help!
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Mini Margaritaville Truck (A55853)
Mini...
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
