JD 5525 Rockshaft Valve Adjustment ????'s
   / JD 5525 Rockshaft Valve Adjustment ????'s #1
rutwad
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
On a JD 5525 MFWD, cab, 24f/24r, does anyone know where the valve is that adjusts the hydraulic flow to the rockshafts? Not the control inside the cab, but the one under the cab. How hard is it to access and adjust?
Looks like I posted in the wrong place. Moderators, could you move to JD Owning/Operating.
   / JD 5525 Rockshaft Valve Adjustment ????'s #3
I have a 5425. It has a fender mounted lift lever, at the rear there is a flip up cover.
Under that cover are some adjustment knobs for lift rate, lower rate, and also there is a float knob there as well.
If yours has the adjustment feature, it will be there...
Hope this helps...
Actually, the descent got terribly slow so it went to the dealer. The dealer removed the rear glass to access the valve which controls the hydraulic flow. That along with spreading the tires came to over $500 just for labor!
   / JD 5525 Rockshaft Valve Adjustment ????'s #5
Ouch, did they give you fair warning???
Not at all! Plus they charged for steam cleaning (which there is NO evidence of them doing), AND THEY CHARGED TAX ON STEAM CLEANING!!!
So to adjust the valve, spread the tires, and add water to the rear tires came to $800 :eek:.
   / JD 5525 Rockshaft Valve Adjustment ????'s #7
I would ask for a full estimate for repairs and no repairs allowed without my full consent. I tell the service manager to call me if it goes over the estimated amount.
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
2022 Kubota B2601 (A50123)
2022 Kubota B2601...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
