how to center tractor on trailer
   / how to center tractor on trailer #1
Big Bri
Kubota MX5100
ok so i've found another trailer. 20' goose with WOOD deck. The center of the two axles (space between the tow axles) is 104" from the front of the deck.
my center of my tractor would fall at that spot plus or minus 6" with the blade fel touching the front of the deck. the center of my Rear tire is 144" from the front of the FEL. would the weight be shifted to far to the rear of this trailer?
I have a kubota mx5100 with fel, and filled rear tires (water) will also always have ether a 850 lb box blade or a mower of some sort on the back of the tractor when transporting. total length of tractor fel and box is 16'6"
thanks again for help finding the right trailer
brian
   / how to center tractor on trailer #2
A little difficult to determine what you are asking. With an overall CUT, FEL and boxblade length of 16'6" you should be able to obtain a reasonable balance on a 20' trailer. Ideally, 10-15% of the load wt should be on the GN hitch. Sometimes to get the right balance, I will load the tractor backwards. With the fluid filled tires and box blade on the back, the back is heavier than the front. I would have to see the trailer and tractor together, but I would guess the rear tires would probably sit just behind or over the rear axle of the trailer with the load you describe.
i guess what i'm asking is where would i want my rear wheels of my tractor to be. with this trailer they would be about 1 to 2 feet behind the last axle. I've never owned a goose so will that make me to light up front? i'd hate to buy the wrong trailer and not like the way it pulls. (this trailer is out of state so i'd be buying it sight unseen)
   / how to center tractor on trailer #4
What size of truck are pulling it with?
You would most likely be fine with that trailer if you back on.
i have a one ton ford.
backing on with a box blade i can under stand but if i back on with a 6' bush hog(i think my hog is 115" long ) i think the rear tires will be in the same place which would make it worse because now the whole tractor is behind the axle:(:(
i'm going to see if i can get him to send me a pic of the trailer so i can post it. that might help
   / how to center tractor on trailer #6
My trailer is a 25' with a 5' dovetail, triple axle that I currently pull with a F-350. I generally load my heaviest tractor(MF 5455) with the rear wheels just behind the rear axle, more or less centering the weight just forward of the axles. Having the FEL on or off doesn't seem to alter the distance very much. I like to see the back of the truck start to squat, but still not put too much weight too far forward. My lightest tractor(Montana T7074) I actually load a little farther forward to put a bit more weight on the hitch.
Actually my loading distances where arrived at by trial and error, so I don't know that there is a tried and true formula for every combination, except for the before mentioned ideal of 10% to 15% of the weight on the hitch. I don't know if I load technically correctly or not, but ride and braking are good the way I load.
Here's a pic of the trailer as you can see the axles are about centered on the trailer. . . is that going to be a problem?
Thanks again for all the help
   / how to center tractor on trailer #8
You don't want that trailer.
The axles are not placed right, especially for a gooseneck, and it will be about impossible to load right no matter what you do.
   / how to center tractor on trailer #9
I agree with Duffster. The placement of those axles are strange, especially for a GN. Most GNs tend to place the axles much further back. (I often think too far back on some trailers.) You will have trouble balancing your load unless you set the FEL on the GN. Also with the flip up ramps, you probably won't be able to load your tractor, FEL and 6' mower. The mower may need to hang a little off the back and the ramps won't allow that unless they are removed after you load (unless you put the FEL on top of the GN).
   / how to center tractor on trailer #10
If you have the July/August 2009 issue of Boating Magazine (CLICK HERE is the website but I don't see the article listed there yet), they have a good article by Dan McCosh on why to have your trailer loaded properly, and where the weight should be to get it loaded properly, along with illustrations. It starts on page 60 and is called "Shake, Rattle and Roll".
Even if you don't have a boat, it's a pretty good mag since they also test trucks with towing loads (have some of these on the web site).
It's copyrighted I'm sure so I'm not posting it here, but if you want a copy just PM me your email address and I'll send you a scan of it. Hope they don't mind....if you like it, subscribe :p. It's 4 pages and about 6.5 MB, so it might take a bit if you're on dial-up still.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
1012 (A51573)
1012 (A51573)
