The Haymaker
Back to the original thread, I'm curious. What is the actual failure on the spindle? Is it bearing surfaces or something else?
That blows. I'd start harassing New Holland about the change simply because, to me, upgrading a part on a 2 year old piece of equipment would be for only two reasons. They made a slight change so it would work in another piece of equipment to drop mfg. costs, or there was an obvious design flaw in the first version so they revised it. Any car or bike I have ever worked on has been that case. For instance, the clutch bushing and oil seal on a y2k XR650R dirtbike. Both were prone to fail easily, quickly, on the first two years of the bike.
If you had a good shape spindle to compare, I'd be curious of two items. The diameter of the spindle at the bearing locations, and the length of whatever maintains bearing spacing. If the bearings were ever preloaded to heavily, it'd push the inner races towards each other. But, that wouldn't explain the first failure unless it was overdone at the factory. Was the original shaft blued from a high heat condition?
I find it hard to believe too much belt tension would cause a premature failure. A chain drive yes, but seems to me a belt jus wouldn't be capable. I could be wrong though, done it many times. Trouble shooting is tough when doing it over the net!
Suppose I should get my butt to studying for my written exam tomorrow.....
Rayrla - if you're still out there - how much time does it take you to mow, and how often do you mow (weekly?)?
Haymaker - I was looking at the parts break-down for your mower on the NH site. What tensions the belt? That is just one humongous belt, isn't it?
Still don't understand why you are having belt related problems.
I sure don't either, but maybe this is more of a spindle issue than a belt issue. Interesting point: now that I have two new style spindles on the mower, the belt tension got a little tighter (at the same spring length), which I think tells me the new pulleys are a hair larger diameter. Do me another favor - even if it's over the winter. When you have your covers off again, measure the distances between the center points of the spindle pulleys, and also between the centers of the middle spindle pulley, and the fixed idler pulley. Please don't make a special point of this, because I feel I've imposed too much on you already.
I've sent a second request to NH without so much as an acknowledgement.
