Triaxle: Upgrade to E Rated Tires?
   / Triaxle: Upgrade to E Rated Tires? #1
RichT
Fallbrook CA
Kubota B26
My 2007 triaxle boat trailer carries almost 10K lbs of Regal Cabin Cruiser. With the trailer weight the tires are carrying approx 12.5K lbs. The Carlisle D rated tires on my trailer are starting to show significant sidewall cracking. My calcs indicate the D tires are fine for this load, although most local tire dealers are recommending an upgrade to E rated tires for extra safety margin. I'm all for extra safety margins, however, the wheels (Carlisle 15x6 6 bolt spokes) are rated to 65psi (the D rating). So to take full advantage of the E rating (80psi) I'd need to upgrade the wheels as well. Options:
1>replace with D rated (NOT Carlisle's)
2>replace with E rated, keep existing wheels
3>replace with E's and new wheels rated to at least 80psi
Option 3 is roughly twice the cost of options 1/2. What think ye towing experts?
   / Triaxle: Upgrade to E Rated Tires? #2
Don't you have plenty of "safety margin" with just the D range tires?
   / Triaxle: Upgrade to E Rated Tires? #3
sometimes sidewall cracking can go on forever. I'd get 2 spares and keep going till they start blowing.
then replace them with another brand, maybe truck tires.
I've had trailer blowouts before. even with a single axle, its no big deal. with a tri-axle. you may not notice apart from the added drag.
   / Triaxle: Upgrade to E Rated Tires? #4
If you do upgrade to load range E, they need to be on rims rated for the pressure.
Do you physically have room to go to a slightly bigger tire? That would also increase the tire's load carrying capacity even for the same-letter load rating.
   / Triaxle: Upgrade to E Rated Tires? #5
I deal with this all the time. Its not that they are D range or E range its that they are Carlisle tires. They are absolute Junk. Get a set of Green Ball Tow Master Radials or some other brand that has a good rep. I have the worst luck with Goodyear and Carlisle and have been having good luck with a lot of the Chinese tires and the Green Balls the last couple of years.
I ran into the same issues the same year I bought my WellCraft. It weighs 15,600# and I blew 3 of the 6 tires in one trip when it was only 2 years old. Switched over to the Green Balls and zero issues in 3 season and about 3,000 miles of towing each year.
If my math is right each D tire is carrying about 2.1K lbs and they are rated around 2.5K lbs, so yes there is a safety margin. The E tires would add another 300-400lbs at 80psi.
Not really enough room unless I do some weird stuff with the axles.
The tire dealer I trust is recommending AGAINST the Carlisles and recommending for the Greenballs. They've stopped carrying the Carlisles because of high returns/failures. If I do rims and tires I think they'll give me a healthy discount.
The way I look at it...driving this rig I have enough to worry about without sweating the tires.
   / Triaxle: Upgrade to E Rated Tires? #7
Nothing wrong with going the safe route but I run Load Range D on the boat pictured above. The trailer is a 18,000# Eagle with 3 6,000# Dexter axles and it does just fine. Like I said the boat weighs in at 15,600#. I have weighed it.
If you have to do stuff with the axles just be aware there is more to it than you think. Axles have a built in arch. They are also directional since the brakes have a left and right side. I am assuming you are talking about doing a axle flip. To do this right you need to have a axle flip kit installed. Watch your height. My boat sits 13'6" high as is so raising it would cause problems with bridges and such plus you raise your CG which may cause trailer handling problems. One other consideration is if you raise your trailer you will now have to back it in farther. This may put your truck in the water and with that type of load I do not like to get the rear wheels wet. Just some things to think about. I have been down this road before. If it were me I would get the Green Balls or some Denmens in the stock size and be done with it.
Chris
   / Triaxle: Upgrade to E Rated Tires? #8
I'm not the towing expert that the guys above are. However, I'm a CDL driver towing a 19,000 lb backhoe on a 15 ton trailer and a 7,500 lb tractor on a 12K trailer, but I do have some advice for you:
Don't bother with the E's or the E rims. You have plenty of safety margin and you have 3 axles, not just 1 or 2, so a blowout shouldn't be too serious if your tires are healthy.
Just put D range tires on it. If the ones you have now have worn tread and/or bad sidewalls, replace them with quality tires. However,the little secret most guys don't know is you need to check the AGE of the tires you buy. Many tires we purchase are OLD and actually going to be considered too old for useage right after they're installed! Some guys get bargain prices on tires, guess why? Because the dealer knows they're OLD and wants to get rid of them!
My wife nearly lost her father to a blowout caused by tires that were too old. They look fine, but are in the process of breaking down.
I wouldn't worry so much about brands, although I avoid chinese tires like the plague, and worry about proper ratings and checking the date when the tires were made.
Here's a link to explain what I'm talking about much better:
Tire Age Code - Determining The Age Of Your Tires Could Save Your Life! Car Buying Tips To Save You Money
Thx everyone. This forum never ceases to amaze me...tractor folks are among the most helpful in the internet universe.
Not sure which way I'll go, except I WILL replace the Carlisles, which are about 3yrs old according to their code. Tire dealer is having a big rim/tire sale at end of week, so I'll compare the D replacement (7 incl spare) to a full E rim/tire replacement with their discount.
Chris, I appreciate you weighing in with boat trailer experience. The dealer is pushing Greenball as well. I assume you are using E's with that load - nice boat btw.
Next trailer project: converting surge disks to electric over hydraulic.
   / Triaxle: Upgrade to E Rated Tires? #10
I would stay away from the elec/hydro like the plague. I have 2 customers with them and hate towing them. Very expensive, not very smooth, and 2 systems to maintain. I would put surge disc brakes on a trailer over them or even some of the new electric drums that are approved for fresh water. Not sure if the last option will work for you seeing your local.
Chris
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Super Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
UNUSED GRASSROOTS IMPLEMENT 4' BOX BLADE (A58375)
UNUSED GRASSROOTS...
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
FORD 4600 TRACTOR (A58375)
FORD 4600 TRACTOR...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
UNUSED IRANCH IREA5 HYD THUMB CLAMP (A58376)
UNUSED IRANCH...
