fabbing a pto splitter for a pickup truck?
   / fabbing a pto splitter for a pickup truck? #11
An extra two gallon antifreeze reservoir on the firewall would work for the contingency you suggested.
I would think twice on plastic tank unless it was really heavy duty fluid can get hot and wouldn't want the tank to let loose and drop hot fluid on the exhaust manifold.
I blew an lube oil line on an old pick up truck once and that hot oil went up like a blow torch.
tom
   / fabbing a pto splitter for a pickup truck? #12
If you live in the midwest...you may want to check out Bailey Hydraulic Cylinders Manufacturer for your hydraulics. (I just ordered from them a month ago for my log splitter hydraulics..they are reasonable) I also picked up a new 2-stage pump on E-bay for about $100-$120...just have to keep watching.
Good Luck!
   / fabbing a pto splitter for a pickup truck? #14
Case IH 496 Disk (A59814)
Case IH 496 Disk...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
John Deere 5100M (A53317)
John Deere 5100M...
Drago Olimac 6R Corn Head (A59814)
Drago Olimac 6R...
