Gas Welding and Cutting - Safety Gear
   / Gas Welding and Cutting - Safety Gear #1
Beltzington
Appling, Georgia
JD 3720
Just bought a Smith Cutting and Welding Setup and would like to know what more experianced folks use for gloves and goggles.
I have a pair of wrap around Oakley's ANSI impact rated and fairly high UV ratings. Any reason I need different glasses.
Looked at the leather gloves where I swapped my tanks at and they seemed a tad heavy for gas work. Are lighter weight leather gloves ok or should I buy the elbow length cotten lined ones and get on with it?
TIA
   / Gas Welding and Cutting - Safety Gear #2
When gas cutting, I normally use regular leather gloves and a tinted face shield.
   / Gas Welding and Cutting - Safety Gear #4
Shade selection
Light cutting, up to 1 inch 3 or 4
Medium cutting, 1 inch to 6 inches 4 or 5
Heavy cutting, over 6 inches 5 or 6
Gas welding (light), up to 1/8 inch 4 or 5
Gas welding (medium), 1/8 inch to 1/2 inch 5 or 6
Gas welding (heavy), over 1/2 inch 6 or 8
For what I did at work, a #5 face shield worked great. A good pair of leather welding gloves although thick, are a good idea. Shoes are very important since they are usually under your work while cutting and pant cuffs are a bad idea.
   / Gas Welding and Cutting - Safety Gear #5
Tip #2; Big red beebee's will burn through 2 layers of clothing.
The layer after that is skin. :eek:
   / Gas Welding and Cutting - Safety Gear #6
Even when arc welding, I usually just use unlined cowhide gloves. I like the dexterity. If you're planning on picking up hot metal, use the cotton lined gloves and plan to replace them often.
   / Gas Welding and Cutting - Safety Gear #7
Welding gloves plus a proper cutting shield is a start, Personally i like the goggles better.
You should get yourself a welding jacket too. Especially if your going to be cutting overhead. Your shirts will thank me.
And wear boots, keep your pantlegs outside of them too. Those little sparks can find flesh like nobodys business. Nothing worse than one in your boot, except maybe your ear :eek:
   / Gas Welding and Cutting - Safety Gear #9
Don't forget a hat, burning hair smells terrible:D. Also some way of dousing a fire, either an extinguisher or some water close by.
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
