Can my B3200 handle a 7' 3ph finish mower?
   / Can my B3200 handle a 7' 3ph finish mower? #1
B3200
Erie Pa.
kubota b3200
I just purchased 14 acres of open field and I know my 5' belly mower will feel way too small, Will my b3200 handle a 7' finish mower?, thanks for any input.
   / Can my B3200 handle a 7' 3ph finish mower? #2
My thoughts would be a 6 foot would be most appropriate.I'm thinking a 7 foot might be a little heavy,regardless of the HP requirement.Your B3200 would normally use a 5 foot rotary cutter or 6 foot rear mower.Good Luck.
You may be right, if so I would swap out my 5' belly mower for a 6 footer
   / Can my B3200 handle a 7' 3ph finish mower? #4
well... I don't know. But the 3030 handles a 6 foot mower effortlessly, so I'd bet if you didn't let the grass get too high between mowings you could make it work...
   / Can my B3200 handle a 7' 3ph finish mower? #5
I used my first 6'RFM on a B7800. It was a light weight deck and the tractor handled it effortlessly but the deck kept tearing up. Traded it for a Landpride 6' RFM that's built like a tank. The B7800 and the L3240 handled it but the L3240 would slow down near the crest of the hill. The B7800 had no problems with keeping power but when I would reach the bottom of the hill the deck would sort of swing the tractor which was no problem because I knew it was going to do it. I now do most of my mowing with my BX2660 so I don't need the RFM. Paid $1750 for it, will take $950 for it. Never really used it over 6 times on about 3 mowed acres.
   / Can my B3200 handle a 7' 3ph finish mower? #6
Some of this probably depends on what mower. I think there can be alot of difference in weight when you talk quality of construction. I had a 5 foot Land Pride RFM on my B780 and moved up to a 6 foot Land Pride. My B7800 would cut with it but I felt it was working my HST pretty hard. I had some slope to my yard (about 3 acres). On my B7800 I wouldn'd want to have used any bigger mower.
Another things to consider is fitting a 6 versus 7 around obsracles, through gates. I mow my ditch with the 6 not sure about that if I had a 7 foot. What about fitting a 7 foot on a trailer if you need to transport things?
That being said since I've sold my B7800 for a L3940 I'm keeping my eye out for a deal on a 7 footer.
   / Can my B3200 handle a 7' 3ph finish mower? #7
darn, I wish you were closer, I'd buy it.
   / Can my B3200 handle a 7' 3ph finish mower? #9
Contact Barlows and see if they have a delivery in your area. They would bring it for fair price if their driver is coming that way.
Thanks for all your responces, the lot i am purchasing has a gentle slop, no trees and flat, (not bumpy) and I wouldn't have to lift it with the 3ph.(I think). If I can I will borrow or rent one to test it out.
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
1993 PETERBILT 362 SLEEPER (A54607)
1993 PETERBILT 362...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
91013 (A48082)
91013 (A48082)
