FEL 4X4 or not
   / FEL 4X4 or not #11
Great advice given so far,just because one has 4wd doesn't mean they have to use it,but if the time should come you won't regret it...now where did I read 4wd frontend are stronger than 2wd frontend.
They're not. In fact, I'd bet a 2WD front end is stronger from a reliability, cost to repair and durability standpoint.
Usually compact 4WDs will lose front end seals. They are expensive to fix. Tires are more expensive, too.
I have little use for a 2WD, but the guys that know their limitations definately save money at purchase and in maintenance.
   / FEL 4X4 or not #12
Are you looking at an equal size replacement?? Utility like your 35, not a compact.
   / FEL 4X4 or not #13
Durability of the front end, loader frame, etc, is actually a bigger issue with a 2wd than a 4wd. One might think that a 4wd would cause higher stress on these components, but, because a 2wd operator often has to use momentum to assist in getting a full bucket, while a 4wd operator can just power into a pile smoothly and without loosing traction, the reverse is true. Even a novice has to try real hard to damage a 4wd loader, while a pro can wreck a 2wd in short order if he is under the gun to get a job done. Broken welds, etc are much more common on 2wd loader frames for this reason. The only way a 2wd tractor is effective on a loader is if it carries a very heavy load on the rear axle, and that will cause issues with trailerability, soil compaction, tire longevity, fuel consumption, and overall stress on the machine. Also, as already mentioned, 4wd will cost you some more up front but you will make that up and then some on resale of any loader tractor. If you are one of the few who can get away with a 2wd loader tractor then I would strongly reccommend going with a used machine so you dont get hit with the massive depreciation that you would absorb if you buy a new one. Used 2wd loader tractors are selling today for pennies on the dollar, while you got to look real hard to find a "bargain" 4wd.
   / FEL 4X4 or not #14
When I bought my Kubota I was concerned about the strength of the front 4WD differential. This is my first 4WD tractor. But after two years and 400 hours of trouble free with the 4WD I would never do it any other way. I have zero seal problems. The front tires are an issue. I have R4's all the way around. The rears are still like brand new but the fronts are wearing quickly. The wear on the front R4's is the only disappointment I have in this tractor. They will be expensive to replace. I only use 4WD when doing loader work.
   / FEL 4X4 or not #15
From a safety standpoint, when you are locked in 4wd you also have braking power to the front wheels. A big plus when carrying a heavy load and reduced traction on the rear wheels.
   / FEL 4X4 or not #16
From a technical aspect 4x4 is probably better "if" you do a lot of loader work. For myself 2wd works very well. I use my FEL about 25 to 50 percent of the time. And that's only because I've been moving alot of round bales lately. Someone mentioned the stress of having to use forward momentum to scoop a bucket full of dirt with a 2wd and just power in with 4x4 on the front axle. I don't see it as the stress is in the bucket not on the axle during the scoop portion of the load. Also selecting the right gear (if that's what you have) helps. When moving dirt I generally use the "A" range and using the shuttle to change directions I've never had to use the momentum of the tractor to scoop full loads.
I don't know and I could be totally wrong but if your Job is loader work then yes an industrial loader would be ideal but if you're a weekend tractor operator then I feel knowlege of your equipment and knowledge of the job will work more for you.
   / FEL 4X4 or not #17
You said you have a MF 35 do you have PS on it if not when it is loaded you will have a hard time steering it.
   / FEL 4X4 or not #18
4WD and power steering as I now have on my JD 3520 sure make things easier and much more comfortable, but I used my MF 35 and her FEL for 14 years to carry dirt, stones, tree trunks, pull out stumps or do a bit of grading and found them very efficient too.
   / FEL 4X4 or not #20
This debate is often had on here but to me , living in a place that has snow, ice, and mud four wheel drive is a necessity. Funny thing is I never was convinced of that until I got a four wheel drive tractor. :eek:
You can always "get by" with two wheel drive, but if you are buying new, try 4wd -- you will like it!
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
MISC BASKET OF HYDRAULIC PARTS (A53843)
MISC BASKET OF...
Case 1083 20ft Corn Head (A53473)
Case 1083 20ft...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
