Smoothing up some pastures.
   / Smoothing up some pastures. #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am looking to clean up some property for planting next year. I have some stumps in the area. I am not planning on running a tiller over any stumps, but it might happen.
Maybe I am better off using a cultivator or ripper to break the ground first then use a finishing disc harrow.
Ideas?
I am looking at smoothing around 45 acres. The other 20 or so are smooth - just need to plant.
Thanks,
D.
   / Smoothing up some pastures. #2
Depending on what sort of tractor you have, a good reasonably priced alternative is to use a chisel plow at shallower depth than one would normally use one. Then disc. Old chisel plows are a dime a dozen around here. You just won't find many that a small tractor can handle. (Most are CAT II or CAT III hitch, and H.E.A.V.Y. too) Also consider an offset disc, or what was once popularly known as a "bog disc".
I have a J D5525. 75 HP PTO CAT II.
I have been thinking a used chisel might be the way to go to get the initial rip. I might not rip the whole thing, maybe just there we tore out stump 3 years ago. Break up enough dirt to spread it around.
D.
   / Smoothing up some pastures. #4
D.
You have enough tractor to handle an 8' to 10' chisel at a reasonable depth (in soils typical in MY area anyway)
I found this one locally.
10 Foot Wide Chisel Plow
That might be a perfect fit.
Hit it with a chisel and then disc and then spike harrow. I wonder if those chisels have springs, etc.
D.
40ft Shipping Container (A49461)
40ft Shipping...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
71058 (A49346)
71058 (A49346)
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
International 133 6 Row Cultivator (A50514)
International 133...
