Smoothing up some pastures.
   / Smoothing up some pastures. #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am looking to clean up some property for planting next year. I have some stumps in the area. I am not planning on running a tiller over any stumps, but it might happen.
Maybe I am better off using a cultivator or ripper to break the ground first then use a finishing disc harrow.
Ideas?
I am looking at smoothing around 45 acres. The other 20 or so are smooth - just need to plant.
Thanks,
D.
   / Smoothing up some pastures. #2
Depending on what sort of tractor you have, a good reasonably priced alternative is to use a chisel plow at shallower depth than one would normally use one. Then disc. Old chisel plows are a dime a dozen around here. You just won't find many that a small tractor can handle. (Most are CAT II or CAT III hitch, and H.E.A.V.Y. too) Also consider an offset disc, or what was once popularly known as a "bog disc".
I have a J D5525. 75 HP PTO CAT II.
I have been thinking a used chisel might be the way to go to get the initial rip. I might not rip the whole thing, maybe just there we tore out stump 3 years ago. Break up enough dirt to spread it around.
D.
   / Smoothing up some pastures. #4
D.
You have enough tractor to handle an 8' to 10' chisel at a reasonable depth (in soils typical in MY area anyway)
I found this one locally.
10 Foot Wide Chisel Plow
That might be a perfect fit.
Hit it with a chisel and then disc and then spike harrow. I wonder if those chisels have springs, etc.
D.
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
2013 MACK CXU (A50854)
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
