Wood Processing for burning..
   / Wood Processing for burning..
4300,, Nice to see someone else pulls out with the loader.. you seem a bit high with the bucket though :eek:
   / Wood Processing for burning.. #32
To all:
How is your wood seasoning this year?
We usually have 6 weeks of very hot dry weather in the summer. It has been cool and rainy all summer. I'm concerned that the wood is not going to be dry enough this year.
   / Wood Processing for burning.. #33
To all:
Yeah, I know, same wet weather here this summer :(
Fortunately, we probably have enough left over from last year (3 cord under shelter) to cover us for most of the year. I have another 3 cord cut but not split outside the shed. Plus plenty of trees down in the woods from the fall and winter storms we had last year.
Ken
   / Wood Processing for burning.. #34
I got another large tree out today... I'll split it tomorrow, and I still have 1 large and 3 smaller ones to go.
It's was hard pulling it down hill because the end would dig into the ground... I was able to cut it in half and pull the top part out to where I do my splitting... I then lifted the bigger end up and put a block under it so I could cut it up.. I had to cut it up where I pulled it down, then haul it out 3 stumps at a time.
When I would lift up on the tree and back up, the tractor would try to flip over... And I remember two members on here that done the big flip... I did have my seat belt on:D
I started on this at 2:00pm and finished at 6:33pm.
Also had some rain last night, and that made it worse trying to get traction... I need to get some AG-tires.
After I get this tree split tomorrow, then I'll start again on another one:D
Life is great!:D
Bill not to sound like the safety police but it always makes me nervous when I see someone transporting a heavy load with the loader that high. You really raise the center of gravity and it just doesn't take much to send you over. A method I have used is to get the butt of the log in the loader bucket, raise it about 6", get your chain around it and attached to the hooks on your bucket. That will allow you to move with the bucket close to the ground and the center of gravity much lower. Of course you will still want good ballast on the rear of the tractor so as not to over load the front axle with weight.
Looks like you have gotten some nice firewood there.
MarkV
   / Wood Processing for burning.. #35
Good thread. Few things more rewarding and enjoyable than processing and seasoning your own firewood IMO. I also enjoy seeing how efficient I can be while doing it. My preferred method starts with dropping the tree and limbing it where it is or dragging it to where I will pile my slash. I then cut it and split it right where it lies. Just tip it up on the ground and smash it with a maul. I know a maul doesnt fit into everyones program but I have found that this is where most of my efficiency is born. Of course I'm still fairly young and foolish:D From there I grab the insert I made for my FEL that I can stack more wood on which allows me to stack a 4x4x20" high pile on and drive straight to the porch and lift it up over the railing where I unload it. This way I only have handled it twice and wont touch it again until i bring it in the house right before I burn it. Of course this doesnt work in every situation.
Last year I had 10 tree length cords delivered in Febuary. I had the driver unload in on a snowbank which worked out well since when I cut it, it was nowhere near the ground to dull the chain. Cutting and splitting in winter keeps a lot of the sweat down and what else do you have to do during the winter anyway! :) I a big believer is splitting by hand right where it lays. If your body can handle it, and the wood is right it will save you a lot of time. I save a pile of knarly stuff and my neighbor comes over with his splitter when I have enough of a pile and we split it up.
   / Wood Processing for burning.. #36
MarkV
No problem sounding like the safety police:D... It makes me nervous when lifting something real heavy with the bucket, because accidents happen very quick...I've lifted a lot of trees and can tell when the tractor wants to raise up/flip over, but every time is different and when I start to raise up my bucket I raise it very slow.. That way I can tell what the tractor is going to do.
At first when I tried to pull it with my bucket a little high, and back up, then the tractor tried to flip over, so I had to pull it with my bucket lower.
When I pulled the tree off the hill my bucket was low to the ground...The top part that I pulled to my splitting area was very light..In the picture when I had it lifted up I started to put a block under it and cut it up there, but it being so light I then decided to just pull it out, and I re-hooked my chain to the tree before pulling it...When I lift a tree to block under it I put down my 'backhoe stabilizers,' and that helps some to keep it from flipping over.
When I pulled the top part out I had my bucket low to the ground. (I should have taken a pic)... The other picture where I had the tree pulled out where I do my splitting, I had my bucket high because I lifted my bucket up to get my chain out, and I took that pic to show where I split my wood... But I could have backed up with my bucket low to get my chain out... For the 'ballast' on my tractor when lifting I have my backhoe on.
On the next trees I should be able to pull some, and I'll take some pictures.
   / Wood Processing for burning.. #37
OK Bill, I understand what you were doing better now. I didn't see the backhoe as ballast when I was looking at the photo's and thought you were actually skidding the log with the loader way up there. Glad you didn't take offense at my misunderstanding.
MarkV
Doc. Mine is doing ok drying,,like you it's been very wet this year,, I still have a cord of wood in the basement,, so I'll burn that first by then the rest will dry pleaty.. I stack up to 6 cord in the basement and after about a month of burning the humidity in the basement is around 15 to 20%,, then I know the rest is getting very dry,, also have a pallet of "bio" bricks coming want to try them out,,:confused:
   / Wood Processing for burning.. #39
Rod,
that looks like an interesting approach. You must have flat land to get around in the snow with turf tires.
I had a carryall, but it didn't hold up. But then I guess it wasn't made for carrying a heavy load of rocks :( But I do like your set up and approach to work.
We don't get much snow here but we do get a lot of mud. Even on gentle slopes in winter I've gotten equipment stuck, even with ag tires. I had one utility trailer loaded with wood that I couldn't get up a gentle slope. I unloaded it and it stayed there until spring....by which time it had two flat tires :mad: Our winter mud here is like grease.
Ken
I can get around pretty good on the turfs with snow up to the axles, the snow is fairly dry here so even higher than the axles for the first couple of trips, after that it gets harder. If the snow is deeper than that I have trouble walking in it so start to lose interest in working in the forest. Mud not much of a problem either, there is enough vegetation and small branches and twigs to drive around on even when wet. Turfs are a real good fit for me.
The part about varying the work to keep from getting tired out I learned from a neighbour who will be 84 this year. He looks like a fly in a bottle moving around his yard doing different things, never works at any one thing too long but at the end of the day he has accomplished quite a bit. I'm just a kid next to him but have noticed that when I follow his example I too can get quite a bit done without getting too tired out.
   / Wood Processing for burning.. #40
Do you have any pictures of it ? :D
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
