older square baler speeeds
   / older square baler speeeds
I don't know for sure, but I'd be surprised if this baler had been outfitted with a 1000 rpm rig. But I'd also be surprised if it was engineered to be this slow.
I would guess this baler should be comparable to the 14t.
Perhaps I'm spending more down time with that bum knotter than I'm giving credit for? Otherwise, it really does seem to run pretty well.
Thanks for the info on how plunger rate makes for higher productivity. Now that's what I'm talking about...no wonder last year when I was running a 336 for a little while in these same fields it seemed like my life was so much easier. I'd sure like to upgrade to a baler that is just a step up from this as it would better fit my operation. Having guys standing around as I hemorrhage money, and slightly perplexed customers grabbing bales as fast as they can hit the ground out of the back of the baler is not something I want to do every year.
   / older square baler speeeds #12
I have had a Ford 532 for about 4 years. I had a NH 68 before that. To me it seems as though the 532 has a lot more capacity than the 68. The 68 made a neater bale that fit my trailers better. The 532 plunger hits the hay and makes a wavy pattern in the hay that once the bale is out of chamber, the waves in hay start straightening out and I end up with a bale that is measuring 15X19. Difference in 532 plunger and the 68's is the NH had a flat plunger face and the 532 has 4 flat steels that go on either side of needles. This metal is causing the the waves. Other than that no problems. One thing you might check is the feed door that you can narrow down or widen up that is located on sheet steel at back of pickup housing and next to chamber opening. It is supposed to be narrow for lite windrows and wide for heavy.Hope this helps.
   / older square baler speeeds #13
Plunger rate sure plays a big part in bale rate. Seem to recall the plunger speed on the JD 336 was 80/min @ rated PTO speed.
Hay fields around here are fairly heavy for 1st cutting and as I recall (been ~25 yrs ago) I was punching out a bale about every 10 strokes. Shot for 50# bales.
Having bales stuck together by uncut hay is saying to me excessive clearance between knives. Saying you recently rebuilt plunger may be a clue. Thinking with heavy slugs, plunger is somehow moving away from the stationary knife. Think I'd look for possible side play in the plunger.
For the missed knot, is it possible timing on the needles are slightly off. Small difference in the knoters making the difference in performance between the two.
Getting every thing just right can be an issue at times. Remember after making the first adjmts on the 336 I started breaking needles, often. Just about gave up and decided to talk to baler mechanic at the local JD shop. First thing he asked was "did I adj the needle timing according to the book", Yep, "there's your problem, manual was incorrect. Made adjmt per mechanic instructions and problem all gone. Expensive lesson. Also had on knoter frame break for no apparent reason.
   / older square baler speeeds #14
I thought the plunger rate on the 336 was a bit higher but maybe not. I can't remember the numbers right now but it seems 250 bales an hour is no problem in good windrows with my 336. I've been baling much slower this year with a wagon behind so the overall process is much faster. About 180 bales an hour but no picking off the ground.
   / older square baler speeeds #15
Otherwise, it seems to be running really well. I'm lucky if I break 200 in an afternoon, so even if the right knotter cost me, say, 50 bales, that's still nowhere close to what I expected from any old baler in pretty decent shape.
Please let me know if there's perhaps something else I might try. After this past week, though, I decided I've plainly got to improve the time it takes me in the field for next season, and the baler is my weak point of the operation, clearly.
Is the plunger chamber being filled for each compression stroke? On mine there is an adjustment in the stroke of the paw that pulls the hay from the lift rake and sweeps it in front of the plunger for compression. Sounds like it is not delivering a full load to the plunger.
larry
You know...now that you mention it, there are some adjustments on the paw that grabs hay and takes it to the plunger. I'll check tomorrow (we're getting rain again, and I've luckily got no hay on the ground at the moment), but I seem to remember that there are a series of bolt holes which allow for adjustment on that.
Thanks for the idea. And I'm going back into that right knotter again. And I'll have a look at the plunger to see if there is play in it that may widen the gap between the knives when a big load of hay comes through as Mickey_fx mentioned.
I sure could be suffering from a lot of little slow ups that make the total a big problem.
   / older square baler speeeds #17
You guys sure do go a lot slower than we do over here!
I run a Claas Markant 65 (don't think they exist in the US) but it is a fairly modern baler, say 15 years old.
I do a lot of contracting (custom small baling) as well as our own hay (about 6000 - 8000 bales a year plus another 10000 - 15000 contracting.
All this is done with a bale accumulator on the back putting the bales into packs of 8.
I aim for 450 an hour average, some times I can get up to 550 bales an hour, other times I am down to 250.
But in a day of say 7 hours baling I expect to get 3000 bales done.
Thats a bale about every 10 seconds.
If you push on too much the bale lengths become erratic, because you will get such large wadges in the bale.
A decent windrow is key, too small and you cannot go fast enough, too big and the packers are overfed and inefficient.
With a decent modern baler it pays to keep the revs right up, I stay at around 560 - 580 PTO RPM which gives about 95 plunger strokes per minute. The faster the packers are clearing the crop, the less they are having to move on each stroke.
You should be baling way faster than anything can pick up and load by hand. Something else must be wrong.
Also, I consider 1 miss in 10,000 bales to need fixing. There is no reason for a knotter to miss unless there was a problem trasnfering from one ball of string to another or similar.
Having decent hay kit just makes everything so nice and easy, the number of times I have been called to a field of hay where a farmer is struggling with gettting it baled, and I pull into the field and start knocking bales out, and the farmer remarks "oh it is so easy when it all works perfectly!"
This is how I like my baler to be going:
YouTube - Claas Markant 65 Small Square Baler Wheaten Straw
   / older square baler speeeds #18
Accumulators and 1/4 turns really allow you to speed up. I can easily meet your totals with my NH 575 if it wasn't for changing wagons every 130-150 bales. That takes up a lot of time unless you have someone following with a wagon so you don't have to travel to the wagon to change. Still it slows the process down considerably. If I recall I did 2600 bales in 6 hours give or take a few years back but had help changing wagons over so I didn't have to run for each wagon with the baler. I would love to go with a Kuhns accumulator and really see how fast I can bale:D
   / older square baler speeeds #19
Your Claas is not faster than a 15 years or newer US baler. My old JD336 run with a JD4430 could outrun that video (as you can see for yourself on many other Youtube haymaking videos. This thread is all about mid-1950 and 1960 vintage balers running with under 40 hp CUTs. Yep, the windrow volume is the key, if a bale takes too long to accumulate sufficient material, it stretches your day. Either pick up your ground speed, double or triple rake your windrows, or go to a wider mower (12' or 16'). If you need 10 second bales, that's about 13 plunges in 10 seconds with a full baler throat. Any modern machine does this rate or faster, especially the 1000 rpm PTO driven machines.
   / older square baler speeeds #20
What brand has a 1000 rpm small square baler?
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
CATERPILLAR D4G LGP CRAWLER DOZER (A52707)
CATERPILLAR D4G...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
