4 in 1 / clamshell buckets..pictures please...
   / 4 in 1 / clamshell buckets..pictures please... #21
I have about 150 very diverse acres from fields, swamp land, hardwoods, etc.
I have 15 acres of Christmas trees to mow around, need to clear more brush/trees/stumps/rocks and prep soil for more christmas trees.
I also have about 100 acres of hardwoods that I need to pull tree tops & logs out. I need to move a lot of large rocks/creek run to fix rutts/etc. in logging roads....Oh and most importantly I need to make food plots for my dear friends....I mean my deer friends...lolo
Steve
I agree with Dangerdoc. You will be much better served by a grapple doing this sort of work. No ifs, ands or buts about it. A grapple would be a dramatic difference improvement in efficiency compared to attempting this sort of work with a 4n1. The grapple, even a light duty one, will also take much more abuse and is easy to repair. 4n1 buckets can be knocked out of true pretty easily when dealing with rocks. If you already have the 4n1 as a general purpose tool, you will find soon that another $1000 for a 48 inch light duty grapple will be money very well spent.
Thanks for the information. Well I know the Frontier grapple was around $2400?
I'm hearing what you & Dangerdoc are say'in and from your pictures I think I should own one. Would you happen to have a link where I could buy a decent light duty 48" grapple for around $1000.00 that would hook up to my 400cx loader?
I think from researching old threads the grapple you use is no longer produced?
Thanks,
Steve
   / 4 in 1 / clamshell buckets..pictures please... #23
Thanks,
Steve
This is what I use.
Markham Welding - Extreme Gator Mini Rake
This is similar to what IslandTractor uses.
Markham Welding - Light Duty Grapple Rake
You would probably be better served by the lighter wider version but both are about $1000
If you don't have a skid steer connection, you will need an adapter but it is a good investment.
   / 4 in 1 / clamshell buckets..pictures please... #24
I agree that a 48 inch grapple from Markham would be the way to go. I have a similar style/weight grapple on my DK40se which has a 2700lbs lift capacity which must be close to that of the 400cx. The grapple does fine and you really don't need a heavier, larger or more expensive grapple for the sort of work you are describing. I'd suggest reading some of the threads on the Markham grapples before you order, you will want to specifiy pioneer hydraulic couplers rather than the more expensive flat type and you may want to opt for intermediate bottom tines to keep small brush and rocks from falling through. Again, spend a while reviewing previous posts on either the Markham or Millonzi grapple and you will get a good feel for what these tools can do.
Thanks for the web links and additional information! ~ Very much appreciated.
~S
   / 4 in 1 / clamshell buckets..pictures please... #26
as per Island Tractor I have the small millonzi. I use it on the 59hp tractor with no real issues (bent tines, don't care about that).
I've not bought the grapple from markham, but have bought enough stuff there that I'd have no hesitation doing so.
And I'm with dangerdoc on the d*** deer. No need for foodplots - they regard my whole yard as a food plot. I've had to chase them just about off the porch at midday.
Hello,
Just looking for a little more information in regards to the Markham grapple. I have a 400cx loader on my John Deere so I would need the Markham 48" grapple that would go on a skid steer then buy a conversion kit or something so it would fit on my 400 cx? All in all any idea of price with the grapple and conversion kit/etc. Also is the kit/parts hard to install? Thanks for the help all new to me.............
Thanks,
Steve
   / 4 in 1 / clamshell buckets..pictures please... #28
Hello,
Thanks,
Steve
I do believe they will build you a grapple with the JD style connection. Last I priced one they were a grand-ish. Then, obviously you will need a hydraulic circuit of some sort plumbed to the loader arms to operate it.
   / 4 in 1 / clamshell buckets..pictures please... #29
Looking at their site I see they most definitely do make them with a JD style connection.
Excellent..thanks ! Sounds like it should be an easy hook up.
~S
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
71067 (A49346)
71067 (A49346)
2014 Freightliner Ambulance (A50323)
2014 Freightliner...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
