Putting up a metal garage ceiling with my tractor
   / Putting up a metal garage ceiling with my tractor #1
carpenter383
Indiana
Kioti DK40SE
Here are some pics of my weekend project:
I bolted a 10ft wide frame built out of lumber to my tractor bucket (the holes were in the bucket from the factory) and used it as a platform to lift 20ft and 16ft sheets of metal to the trusses which are 12ft high. and 4ft O/C.
It worked out great and I was able to get it all done in most of last weekend by myself.
I'm gonna blow about a foot or so of insulation on top of the metal. I framed the walls with 2x6's and used r19 in them and I think it should heat pretty easy this winter. I'm gonna heat it with a wood boiler:D
   / Putting up a metal garage ceiling with my tractor #2
thats ingenious. Could hang drywall with ti too if needed.
   / Putting up a metal garage ceiling with my tractor #3
Great job. I plan on using the white metal siding for the ceiling when I get around to having our pole barn built. Thanks for posting the pics, great idea and set up with the FEL.
   / Putting up a metal garage ceiling with my tractor #4
Great idea! Good photos, too. It looks like it came out very well - thanks for sharing with the photos.
   / Putting up a metal garage ceiling with my tractor #5
Impressive!
   / Putting up a metal garage ceiling with my tractor #6
Looks good. I need to do that as well. Too bad my ceiling is 14' high. :(
   / Putting up a metal garage ceiling with my tractor #7
Looks Great ! ! ! Like the frame for installing the panels Great idea
   / Putting up a metal garage ceiling with my tractor #8
That's really slick. I am also very glad none on the pieces slid off and made two parts outta you! You got a huge amount of work done...really impressive.
Peter
   / Putting up a metal garage ceiling with my tractor #10
Carpenter,
Excellent example of what can be accomplished in a weekend by a clever man and a versatile tool.
With 4' O/C truss spacing, do you have any concerns about undesirable deflections of the ceiling under the load of 12" of blown insulation?
- LogChain
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
Trommel (A52377)
Trommel (A52377)
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2018 John Deere 325G (A47477)
2018 John Deere...
