how mush does my tractor weigh?
   / how mush does my tractor weigh? #1
mostly_gas
Super Member
Texas
in-between tractors
I need to buy a new trailer to haul my '79 1700 w/ 770 FEL and was curious as to about how much it weighs?
   / how mush does my tractor weigh? #2
Welcome! I hope you enjoy the site, I'm sure someone will be along that can supply some info.
But of course a lot depends on the configuration, tires, etc. And, are the tires loaded? Do you have weights on it anywhere? Stuff like that.
Do you have an owner's manual? Sometimes the empty weights are in there.
I know I'd like to know more about my weight, CG, etc, but it seems that the only way I'll be able to do that is either by taking it to a scale, or lifting it end-by-end with a pancake jack that shows the pressure in the cylinder. You multiply the pressure by the cylinder ram's area to get the force.
   / how mush does my tractor weigh? #3
Tires are not loaded per previous owner. no weights, unless I am using FEL. Tire size rear 11.2-24 ag type front 6.00-16 ag type. Manuals: I&T FO44 and 770 operators manual, neither give wieghts. Thanks for the link to the general tractor info.
I used a 12 ft utility trailer w/ 5,000 lb. axle. Rig or tractor were never weighed.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2020 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2020 MACK PINNACLE...
200387 (A51247)
200387 (A51247)
2020 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A53426)
2020 FREIGHTLINER...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
