Confused About HST Fan Protection
   / Confused About HST Fan Protection
No, I was wrong. It is indeed bolted on. That is good news for possible retro fits on other BXs.
There are extension arms I did not notice, at first. These extend toward the rear of the tractor and are heavily bolted with two bolts per side.
One more thought here, I don't believe Kubota set out to offer a true skid plate. That bespeaks a level of protection that is sober and intentional.
I simply suspect they set out to offer a genuine fan protection system. In that, I believe they were reasonably successful.
   / Confused About HST Fan Protection #23
Anyone attach the BroTek to a BX2660? I'm considering it but don't want to be the first to do so. Hopefully the hole for the MMM shaft works well.
   / Confused About HST Fan Protection #24
I am also interested and have some concerns about restricted air flow, especially during times the MMM is on. Since I only take my MMM during the fall and winter, I am considering the advisability of taking it off when I install the MMM as that will be during the hot summer months.
   / Confused About HST Fan Protection #25
BP - as others have already stated, that is a vast improvement over no skid plate and 100% better than the first version Kubota came out with. Are you sure your dealer didn't take two of the 1st gen Kubota fan protectors and tac them together somehow? - almost looks like two of those 1st gen protectors connected together.
Also, for anyone considering the Bro-Tek skid plate, I only needed to loosen the front U-bolts about half way to remove my HST filter from the side. I may have removed the right rear wheel to do that thought - can't recall for sure, but if so, still easier than taking the skid plate off. I still highly recommend the Bro-Tek version as it is a true skid plate that protects from forward of the fan to the rear hitch plate, including the entire bottom of the HST housing.
   / Confused About HST Fan Protection #26
Has anyone who is running a Bro-Tek or other skid plate noticed any increase in HST temp or any symptoms of increased HST temp? I am considering a skid plate but I'm concerned about overheating the HST. Thanks.
Matt.
BP - Are you sure your dealer didn't take two of the 1st gen Kubota fan protectors and tac them together somehow? - almost looks like two of those 1st gen protectors connected together.
Chris, No I don't believe this was a dealer installed option. I do believe it is a Kubota "quiet" upgrade. I believe people should expect to see more. My tractor was assembled in late May, so it is very new in the pipeline, I suspect.
   / Confused About HST Fan Protection #28
Matt.
First of all- there are no needle or digital readout temp gauge for hydralic fluid on the BX'es so with or without skid plate, there seems to be no way of knowing.
   / Confused About HST Fan Protection #29
I have the "old" new fan protector and would be interested in the "NEW" fan protector part number so I could order one. Somebody must know what it is.
Bob Cramer
   / Confused About HST Fan Protection #30
Bob Cramer
And what was the cost? I have never had a problem in almost three years out in the woods with no mmm on. but also do not wont one ether! If it is as much as BRO guys I will make my own.;)
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
