Water in hydro fluid....made a dumb mistake.
   / Water in hydro fluid....made a dumb mistake. #1
JSUnlimited
Ohio
New Holland
Yesterday I was using my TC24DA and bachoe to do a few things around the house when a hydro hose on the hoe broke. I lost maybe 1 quart of fluid or so. After fixing the hose, I topped off the fluid. Getting distracted by child and the dog, I forgot to put the plug back in the fill hole behind the seat. I then decided to power-wash the tractor and during power-washing I noticed that the plug was missing. Of course I'm not sure how much dirt, water and degreaser entered the transmissionion, if any. I had to move the tractor back into the garage which was only 75' or so. The dealer ordered a new plug for me.
I plan to now go ahead and change the hydro fluid/filters just to be on the safe side.
Should I do/be concered about anything else?
   / Water in hydro fluid....made a dumb mistake. #2
You could run it for about 10 hours or so and send some of the fluid sor anaalsis to see what is in it to be safe. Cost about $25.00 . Blackstone labs is who I use in Fort Wayne IN.
You may want to send old fluid before the change to see. Call them and explain situation and see what they recommend. 260-744-2380
   / Water in hydro fluid....made a dumb mistake. #3
It would have been better not to have washed it.
It would have been even better to have replaced the plug.
Tough Luck but hope it all works out all rite 4 U.
   / Water in hydro fluid....made a dumb mistake. #4
:rolleyes:
It's a shame that I spent a lot of time posting pictures and information about splitting my 24DA to benefit fellow members, only to get smart-*** information when I truly needed a good answer as to what to do......
   / Water in hydro fluid....made a dumb mistake. #6
I don't know. But I'd guess doing a full service would flush things. If you want to be double **** (and might be worth it) drain and change the hydro, run it for a bit, then drain and change hydro again. I'd imagine that would get everything out.
   / Water in hydro fluid....made a dumb mistake. #8
I guess some people don't make dumb mistakes.
All I own is a little TZ18DA, and I appreciated all the info you gave on splitting your TC.
If it was mine, I would change the oil and filters like you plan to do.
   / Water in hydro fluid....made a dumb mistake. #9
Definatley change fluids better to be safe then sorry, maybe even do a flush with diesel. I also like to clean my machines feel it is part of proper maintenance, how else would we be able to inspect for broke or loose things? Also when your changing your fluid look for foriegn stuff in the old stuff, water dirt rust.... If it comes out clean then that might help to put your mind at ease.
   / Water in hydro fluid....made a dumb mistake. #10
Don't feel bad. I blew a hose and lost quite a bit of fluid on my last tractor (DX33). Pulled the plug, put the funnel in and realized I didn't have any fluid in the shop. While running to get hydro fluid we had a freak thunderstorm pop up. Needless to say it poured for 30 minutes with my funnel in the plug hole.
Flushed all the fluid, changed filters, and all was good.
jk
   / Water in hydro fluid....made a dumb mistake. #11
Personally I would NOT do that. Do you know for a fact diesel fuel will not attack seals and other soft parts? Diesel can be pretty agressive softening stuff not designed to withstand it. That is my opinion, but it isn't my tractor:cool:
   / Water in hydro fluid....made a dumb mistake. #12
Most definitely! Aside from probable seal damage throughout the system, how would diesel remove water? Alcohol, yes; diesel????:confused:
   / Water in hydro fluid....made a dumb mistake. #13
I wouldn't flush it with diesel either. Then how do you get all the diesel out. Drain it and replace it, then watch it. If it gets milky, flush it again. If it doesn't, leave it alone.
Mine turned up milky once and I have no idea how. Pretty sure it was clean when I got it used. Stays inside, doesn't like the rain, gets washed once a year. One flush with new oil and filters and it has been clear for 2 years.
   / Water in hydro fluid....made a dumb mistake. #14
Don't take the plug out and stick the funnel in till you have all the fluid on hand and ready to pour.
I also do this kind of stuff in side in stead of out side .
   / Water in hydro fluid....made a dumb mistake. #15
Perhaps you should quit while you're ahead. Your first post was less than helpful to Mega Me and this post isn't any better. Most people do not need to be told what they should have done, that's obvious.
   / Water in hydro fluid....made a dumb mistake. #16
No. Just make sure to run it awhile 1st to pick up any water into the fluid or filter so it comes out with the drain. Best to do it at no load - - like jack up the rears and let them spin free. Save the fluid. Water should settle out and you can use it for the front differential or some other less demanding area than the hydro.
larry
   / Water in hydro fluid....made a dumb mistake. #17
If he just got water and dirt in it I'd save it for sure, the dirt can be filtered out and the water can maybe settle out or be cooked out. But he used a degreaser:eek:
No way of knowing what that might do long term, so if it was me it would become some source of heat, ie burned in some fashion, or taken to the recycle center.
   / Water in hydro fluid....made a dumb mistake. #18
I sure would not use it in the tractor.
   / Water in hydro fluid....made a dumb mistake. #19
I left my tractor outside for quite some time, as I sometimes do, and one day noticed the hydro dipstick was laying on the rear linkage, as if it had just popped out on its own(?) I then used the tractor for a while before I realized it had been a while since the last time, and therefore may have collected water.
Anyway, I ran the system up to temp, drained, and refilled. Then I repeated the process. So, two fluid and filter changes in a single day.
A few TBN'ers had recommended the dual flush. I don't really know if a single flush would've gotten it all out, but peace of mind was what I was after.
Jesse
500BBL WHEELED...
2415 (A60432)
2415 (A60432)
2024 JCB 35Z (A60462)
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2008 HINO 26FT NON CDL BOX TRUCK (A59905)
2008 HINO 26FT NON...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
