mole mounds
   / mole mounds #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Good day, on my property I have tons of mole hills, my airstrip is starting to get mounds, the mounds I want to remove and spread the soil, once I see the new ones appear I will have to deal with the mole, my question is do I use a 3pt rake to flatten and spread the soil or a box blade, on the larger area I do not care if the blade digs in but on the airstrip that is grassed I would prefer to not dig up the grass
   / mole mounds #2
I've had good luck with a chain harrow and making a few passes for pocket gopher mounds. Got anything around that you could just drag?
   / mole mounds
I have a couple of harrows sort of a frame with spikes, for the grass would they work upside down
   / mole mounds #4
I guess that depends on what's on top of them.. some I have seen have handles and the like for adjusting the angle of the spikes. If it's just smooth then that is what I would use. I use the smooth side of my chain harrow. A little speed seems to help as well, I usually use the ATV but have also used the tractor.
   / mole mounds #5
You can use a piece of chainlink fence, or a bunch of old tires tied together. It won't hurt the grass on the airstrip.
   / mole mounds #6
I just back drag them with the FEL when I see em while mowing.
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
