tire keeps going flat
   / tire keeps going flat #1
vulcan101
Member
alabama
kubota L2800
have a l2800 with 7x16 front tires and one of them keeps leaking down..nothing in the tire and have tried sealing with dawn soap around the edges but once a week it goes down.is there a better way to stop this than having to put in a tube.
   / tire keeps going flat #2
Many many threads on this...
I had the problem on the front left of my new BX2660. Every week I had to fill it. Took it once to a tire shop, they cleaned the rim, and rebeaded it. Didn't last. Finally put a tube in it and it has lasted all summer without the need to add air. Hopefully on my property I won't puncture it because then a fix is much more difficult than a tubeless. The other front is still tubeless and working great.
   / tire keeps going flat #3
Just had to replace my left front tire and wheel on my BX2660. I told Davis Farm Supply of my problem and they gave me one free of charge.
   / tire keeps going flat #4
My front tires always leaked since purchase, left more so than the right. But I put a container of Slime in each and have not had a problem for a little over a year now.
   / tire keeps going flat #5
Agree with BotaBX24er....SLIME!!:D
Deano
   / tire keeps going flat #6
Out of 4 BX's purchased 3 have had this same problem. One tire slow leaks and now my Spring purchased BX2660 is doing it. One I had a tube installed and the other I just traded off. May try Sliming this one.
   / tire keeps going flat #7
I put slime in my fronts and end of problem...
I had the rears foamed filled because too many weekend projects were interrupted by flats...
I also bought a spare set of tires and rims and have not had a single problem since...
   / tire keeps going flat #8
Ditto on the sealant for my front right tire. No problems since.
Cheers,
   / tire keeps going flat #9
Foam filling the front tires works well too. But if you do have them filled buy a new set of tires before you fill them. no since in spending the money to fill half tread tires.
   / tire keeps going flat #10
Add me to the long list of "Slimers" I wouldn't be with out it
and the front's are the worst in my opinion.
tom
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
