Well since mine is brand spanking new, something must be going on. As I sit on the tractor (
B3030) it's the left front. I know they are directional, but I believe they can be mounted on either left or right front.
I was also told to take it to my local tire shop, but when they finish with the rim, it'll be "eat up" and the rim edge will look like it has rock rash...so I hate to take it to them to beat on.
John...have you had any issues with your 3200 front tires?[/quote]
None with
B3200, yes with
BX2660. Haven't taken it off yet to get fixed but will. The tire shop shouldn't damage your rim. With expensive aluminum rims that could cost them a few hundred dollars if they damage them has brought about some better tire removal equipment and care. Just ask them and stand there and watch them. It could be as simple as the valve stem and if so, they won't even have to remove tire from rim. If it's a bead leak then it probably won't have to be removed from rim if the reason for the bead leak can be determined. If the tire is bad, get a new one. If the rim is bad, get a new one. Take the tire off and stick it in a wash tub of water and see if you can see any air bubbles. Maybe add extra air if needed. The extra air may make the bead seal if it hasn't for some reason.
