RTV 500 or Mule 610?
   / RTV 500 or Mule 610? #1
janelew21
I've been comparing the RTV 500 and the 610 Mule pretty close and was wondering if anyone recently went through the same process? If so, what did you decide on?
   / RTV 500 or Mule 610? #2
I looked at both last spring. I ended up with the RTV500 mainly because my wife liked it better. I do like the fuel injection which provides easy starting. The Mule 610 you have to choke and let warm up. My wife also likes how the RTV stops when you take you foot off the gas and it is quieter than the Mule. If money is an issue, the Mule is a great value. I liked the glove box with a door and under hood storage on the Mule. Under hood storage on the RTV is a high priced option, like most factory options for the RTV. The Mule has tons of after market accessories where as there is limited after market for the RTV. We are very happy with the RTV and I do not regret the extra money we spent.
   / RTV 500 or Mule 610? #3
Agree with stonehaller on this...The mule might be a little quicker as well.
BTW stonehaller, I looked over my throttle linkage, and noticed that the pedal has ~1/4 travel before anything engages, is yours like that?
Thanks guys, I'm leaning toward the Rtv 500. However, I called about the cost of a snow plow today and was stunned. They quoted me at like $1500.
The Price for the Orange RTV 500 in my area is $7399 and the mule was quoted at $7099. So not a huge difference in intial cost but the implements for the mule seem to be much cheaper.
   / RTV 500 or Mule 610? #5
I to faced this same issue between the RTV 500 and Mule 610. Last week I went with the RTV 500 Camo 7,999.00. I have only put a few hours on it, but so far i like it. It is no speed demon. I only plan to use it on a 14 acre farmette, so it is fast enough. I would like to see more accessories for it and not so expensive. I plan to put a top on it. Also I am looking into a Line X spray in liner. I wish they had a bed liner for it. Overall I am pleased with it.
   / RTV 500 or Mule 610? #6
Line X and the others that do spray in liners wanted $300-400 in my area. I ended up doing a brush on liner myself, Herculiner for $80. It turned out well, but it is a lot of work. If you do use one these kits, be sure to mask everything.
Thanks, yes not looking for speed. Just something to ride around in, plow snow and help around the farm. Thanks for the feedback.
   / RTV 500 or Mule 610? #8
Yes that's what my plow cost too...If you have to plow gravel it's waaaaaay to heavy...Like a cut down truck plow and I'm not kidding. It'll move gravel around like nobody's business until it's frozen solid. Perfect on pavement and concrete.
Was at the dealer last week and they said that there is an aftermarket plow that they can get that is more like an ATV plow in size and weight. Wish that was available when I bought mine.
The machine does plow well though.
   / RTV 500 or Mule 610? #9
I just went through the same process 2 weeks ago. You will like the 500 a lot more than the Mule 610. It is a mini-tank and just seems more dependable. I test drove and compared both at least 4 times each. The mules just didn't seem to "run" as strong. I didn't notice the speed difference between the two. I was thinking the mule might be quicker, but I used my Iphone speedometer when test driving both and the numbers were almost exact. Both units seem to travel more in 18-20mph range unless you have a large flat straight run, then maybe you can top it out higher. I hope this helps.
   / RTV 500 or Mule 610? #10
Shop around for the spray in bed liner. I went with line x and im 100% satisfied. I paid around $70 for a custom job. The Kubotoa dealer wanted over $200. I was told the difference is the material was in bulk containers at my line x dealer so he only had to use what was needed and the Kubota dealer had to open a can that most was wasted and you paid for it. It is such a small bed that $200 is way to much. You wont regret the finish and its rock hard tough. You'll never have to worry about rust.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
Electric Concrete Mixer (A51573)
Electric Concrete...
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A51572)
2000 Isuzu NPR-HD...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
