Anyone experienced in Vinyl Fence Washing??
   / Anyone experienced in Vinyl Fence Washing?? #1
blueriver
Elite Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
We have a quarter mile of 3 Rail Vinyl along the road, its white and some green from the moss, road dust Etc ... Thought we would wash it, so took some buckets with bleach and a brush. That was not the answer. Since there is no running water by the fence ... here's the plan...
I got one of those 300 gallon water tanks, plumbed the end for a garden hose, hooked a 12V RV pump in the line and then to my pressure washer ... this is now in the carry all on the three point and waiting to be tested.
Any thoughts? Think this will wash the fence?
   / Anyone experienced in Vinyl Fence Washing?? #2
12V pump? I don't think it can provide the volume the pressure washer needs. Other then that, It sounds like a plan. Perhaps a gas model pump or a roller PTO pump will provide volume you need in pressure washer.
My pressure washer manual calls for a minimum 2.7 gpm .. the 12 v pump is 2.8 gpm sure hope this is enough.
   / Anyone experienced in Vinyl Fence Washing?? #4
Should work -- pressure washers don't typically need that much volume as you can see by the specs -- just check it frequently to make sure it is getting enough water. In terms of the vinyl, a cheap simoniz electric pressure washer works well on my vinyl decking and fence.
   / Anyone experienced in Vinyl Fence Washing?? #5
I would get a pump-up sprayer and mix cheap dollar store bleach 1 part to 4 parts water and spray the fence about 10 minutes before pressure washing. Spray again lightly after washing for further bleaching and whitening as the solution drys.
Jinman ... thats a good idea. I think I'll use my ATV sprayer for that. The water and Bleach solution should soften the debris and help it come off. The fence has been up for 5 years ... of course you know who pointed it out to me that it needed washing!!
   / Anyone experienced in Vinyl Fence Washing?? #7
I used some stuff called Jomax (walmart/lowes/home depot) that did a good job cleaning vinyl siding.. It is a detergent that you mix with bleach.. Spray it on (using pump sprayer).. let it soak in and the mold/mildew etc starts to run off.. Rinse with water and your done.. May take a couple times if really dirty..
Brian
Brian
Its really dirty and I want it done the first time, I wonder how that would work in the "soap" dispenser on the PW'r??
   / Anyone experienced in Vinyl Fence Washing?? #9
I would stay away from the soap dispenser and use the sprayer as Jinman suggested. Always found it to be better way to dispense cleaners, bleachs etc than through the washer -- JMHO
   / Anyone experienced in Vinyl Fence Washing?? #10
This is exactley how I do it and it works great!
Had I known vinal fencing would the green mold / mildew on it I would never put it up
BLAST SHIELD (A50854)
Case 830 Tractor (A50514)
Case 830 Tractor...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
PAIR OF TALL STACK PIPE RACKS (A50854)
PAIR OF TALL STACK...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
