Jump Start
   / Jump Start #1
Dougryan
Webster, NY
Cub Cadet 3206
Hi,
I have an old MTD tractor that has been sitting for several years. I've almost trashed it a few times, but keep thinking that I could use it to pull my dethatcher or lawn trailer around... Anyway. I'm sure the battery is toast. It will crank a few times if I put my charger/starter on (55 amp boost). It's not enough power to really get it cranking.
So, without buying a new battery, what are my options? I can jump start it from my truck battery? With the truck running?
Thanks,
Doug
   / Jump Start #2
Hi,
Thanks,
Doug
You need a new battery. Once a SLA goes dead, it destroys itself. Sulfation creates impedance, so there is no high-current capability. That's why you can charge it, you'll get voltage, but you still can't turn over the starter. Sometimes you can recover the battery by charging to 2.5V/cell (~15V) for a couple of hours. After sitting around for a couple of years though - I'm betting it's toast.
Just to get it going, however, sure you can jump it. You don't need to start the truck (unless your truck's battery is dead too), just connect the truck battery and start the tractor.
JayC
   / Jump Start #3
I have one of those ctek chargers. Ive used it to recover a couple batteries.Canadian Tire
It wont recover all, but its worth a try. Plus it makes an excellent battery tender to keep your batteries healthy.
The best way to jump is to leave the battery in the circuit and touch the positive lead directly to the starter. You dont want to make a habit of jumping or you will burnout your starter with the high current from an automotive battery.
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
iDrive TDS-2010H...
2018 John Deere Z997R (A53317)
2018 John Deere...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
Zero Turn Mower (A59228)
Zero Turn Mower...
