Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today...
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #1
Owenslee
Farmington MO
Kubota M5040HD 4WD, Ford 8N , White 105, Case 1200 4WD, (1) TO-20 (3) TO-30 Fergusons
Saw the soon to be released latest additions to the Mahindra 35 series tractor line today.
The 45 hp Model 4535 and the 50 hp Model 5035.
Both tractors have a new Canadian made ML130 loader that is quite a bit larger and heavier than the ML120 found on the 3535 and 4035 tractors. Capacity of the new loader is rated at 2700 lbs compared to the 1960 lb capacity of the smaller ML120 loader. The bucket is also larger with a 75.5" measured width.
Also the ML130 loader max height is 111.5" compared to 106" of the ML120. Hydraulic working pressure is 3000PSI.
The new tractors look like a slightly larger 4035 with 4 cyl engines instead of the 3 cyl of the smaller 3535 and 4035.
I did not have access to many specs so I don't know displacement of these larger 4 cyl engines.
Both new tractors retain the 12x12 shuttle three range transmissions.
The weight of the 5035 is 4950 lbs without loader. The ML130 loader adds 1450 lbs.
The 5035 is 129" long and 76" wide ( I measured an actual 75.5")
Tires are industrial versions on both with the 5035 wearing 14x17.5 NHS on front and 19.5 -24 on rear.
The 4535 has smaller 12-16.5 NHS on front and 16.9 -24 on rear.
Both tractors had dual rear remotes installed....however I suspect they were not standard equipment.
Sorry I could not obtain more information but it appears these were early production / evaluation models and little else in the way of specs was available. Both tractors had 26-34 hrs on the clocks.
The dealer indicated that these two models with new loader would be released formally in 60 days.
I thought it was interesting that the ROPS ID plate made reference to it fitting all four 35 Series models. I had not noticed that reference on an earlier 4035 ROPS ID Plate I had seen.
No pricing was available but I have a request for quote in with the dealer.
I plan to take a 4535 home before the end of the year...however they are both very impressive tractors.
Does anyone else have any additional information on these two models or the ML130 loader?
Kerry
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #2
153.9 cu in naturally aspirated. We have had both models in demo status for about 6 months now. Overall comments were "why cant I buy it today" :)
Buck,
Have they fixed the PTO pump on these two models with the addition of the "Cushion Valve" upgrade to prevent shock loading and shearing the shear pins? This was an issue with the early 4035 when it first came out. I ask becasue the dealer with the 5035 stated they had sheared a pin the first time they engaged the electric over hydraulic PTO with a bush hog attached....and now it has me wondering.
Also...the two tractors I saw are for sale now.... I was given pricing on both with $1650 difference between them.
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #4
Buck,
For $1650, I would think that the 5035 would be the tractor of choice. The front tires are bigger than what is on my 7520.:cool:
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #5
Buck,
Production models will include the PTO accumulator but these early release demo models didn稚 and had to be added by the dealer. My guess is the 4535 will not make it to production and they will also drop the 3535. Too much confusion for the buyer and too much hassle for the dealer to figure out what to stock with what options and with what tires. Dealer supplied crystal balls are not the window to the future they are thought to be.
You won稚 feel a hp difference between the 45 and the 50 but the larger sized tires on the 50 make it feel invincible.
Buck
My guess is the 4535 will not make it to production ...
Buck
I'm surprised at your comment as the district rep indicated the 4535 would replace the larger and popular but now discontinued 4530.
Kerry
You won't feel a hp difference between the 45 and the 50 but the larger sized tires on the 50 make it feel invincible.
Buck
I am curious how they get the extra 5 hp rating as both engines are the same displacement and compression ratio and share common design exhaust and intake systems. If it's just in the injection...makes you wonder if the 45hp could be tuned to 50 hp specs....
Kerry
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #8
Kerry
It is just a guess, nothing to back it up except what I have seen from customers on the lot. I have all the models sitting side by side and the only ones that get looked at are the 40 and the 50. That might also be because I have the 45 and the 35 and customers usually want what you dont have (grass is always greener thing). I think the real problem is there just cant be enough price separation in 5 hp increments, they really all cost about the same to build but the lowest hp model in any model run is usually your best seller so you are primarily selling the model that makes you the least amount of money as an MFG. The 4530 was a big seller because it was a 50 or 60 hp size but in a 45 hp consumer price range. Costs to manufacture that tractor though were the same as the 60. Also I expect to see a hydro 35 series coming out, so with four gear models and four hydro models that is 8 models. Four years ago that might have made sense but not now. Like I said just a guess.
Buck
Buck,
Your comments make perfect sense. I also wondered how so many tractor companies can justify such small HP increases between otherwise identical models. The MF 1600 line is a perfect example with 43, 48, 52, 55 and 60HP in the same size tractor. FIVE models over a 17HP spread...
You also confirmed my choice of the 4535 over the 5035....and save $1650 in the process. Besides...its torque that gets the work done in most conditions...not HP. And the 45 and 50 HP 35 series both share equal displacement 4cyl engines....making the 45 the better value for an end user.
I appreciate your insights and candor. If I was closer to you I'd buy from you....but Missouri is a long way to haul 6500 lbs with loader.
Thanks for your knowledgeable input...
Paris Equipment in Paris MO recently sold a 5035 demo model.... the first I am aware of locally.
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #11
Kerry
It is all in the Tier IV engine's emission controls.:( After seeing a Tier IV, I am glad I got a Tier III in my 6520.;)
hugs, Brandi
hugs, Brandi
Yet both the 4535 and 5035 have have Tier IV emmisions...The 5hp has to be from increased fuel from the pump.
I agree with you however that earlier emissions standards would have been preferable.
Kerry
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #13
I went to my dealer this morning for specs on the 5035 and the 4535. He only had specs on the 5035.:( So I called my friend in Tomball that is a tech guru for Mahindra and he stated he never heard of a 4535.:confused: Soooo...........how about a photo of a 4535?;)
hugs, Brandi
You need to find a better informed tech guy....
Note the reference at the bottom of the page:
Mahindra Tractors
Or contact Buck Bond at EFC Equipment EFCTRACTORS.COM
When I inspected both the 5035 and 4535 I did not have a camera in hand.
However, I'll post pictures as soon as I take delivery.
Keep in mind...both of these tractors have not been formally introduced by Mahindra and the 4535 may not be introduced in the US at all. Many dealers I have talked to in person or on the phone are not aware of either new tractor. But those who received the early demo models are aware and were very impressed...as I was.
Kerry
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #15
Mahindra Tractors
Kerry
Kerry,
More photos would be great.:) Is that a side joystick for the loader?:cool: I gather since the 4535 will not be a production model here in the states, the tech guru in Tomball (whose projects are production units) wasn't brought into the loop with the marketing gurus, like a lot of the dealers.:rolleyes: I did find out that the ML130SK loader on the 5035 is made by KMW, which, I think, is still in Kansas........at least on the spec sheet I got. This model is as mysterious:confused: as the 8560.
hugs, Brandi
Kerry,
hugs, Brandi
The loader does have a joystick mounted on a pedestal mounted to the front of the right fender. It is very comfortable compared to the loader mounted joystick of older models. I like the location.
What is interesting is that I also thought the loaders were made by KMW, but the two I saw were clearly marked "Made in Canada" on the data plate.
I have a copy of the full spec sheet for both the ML120 and the new ML130 if you need any specific specs on the 130. I don't have a scanner or I would download it.
BTW, On the data sheet it states: Model ML130 "For use on Model 4535 and 5035 4WD Tractors"
Kerry
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #17
I will see if I can get the KMW rep to chime in here. It might take a day or two.
hugs, Brandi
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #18
hugs, Brandi
Here is Jeremy's reply to my email was.............The cylinders are made in Canada. I know what the question is without looking. Lol
hugs, Brandi
Brandi...
Thanks for the clarification. It WAS the tags on the cylinders I noted.
Kerry
/ Saw the NEW LARGER 35 Series Model 4535 and 5035 Mahindra Tractors Today... #20
I wish KMW would use steal lines with rubbor hoses on all there loaders and have better hoses!
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
Leyman Lift Gate (A59230)
Leyman Lift Gate...
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
JOHN DEERE CP24 ASPHALT PLANER (A60429)
JOHN DEERE CP24...
