HOMEMADE TRACTOR START
   / HOMEMADE TRACTOR START #11
Nice work.
I would look at putting in a transfer case from a 4 wheel drive truck. This will allow you to run it in 4 low and keep the speed low enough while keeping the engine in the power band.
Chris
   / HOMEMADE TRACTOR START #12
Maybe a chain drive reduction 4 or 5 to 1?
   / HOMEMADE TRACTOR START #13
Back in the day it was common to put two (manual) transmissions in series to get the overall gear reduction cheaply.
   / HOMEMADE TRACTOR START #14
C4 ratios are 2.46:1, 1.46:1 and 1:1. In low gear your overall ratio will be 12.644:1 and that will give you an approximate ground speed of 13.2 MPH with 28" tall tires @ 2000 RPM without considering torque converter slippage. If TC slippage is on the order of 5%, your ground speed will be approximately 12.5 MPH. Idling along at 1000 RPM will still have you moving at a good 6 MPH, probably much too fast for most of your needs.
If you could find a T-18 or T-18A four speed transmission, which have 6.32:1, 3.09:1, 1.69:1, and 1.00:1 ratios in first, second, third and fourth, you could get a ground speed of about 2 1/5 MPH in first @ 1000 RPM. Going from a 5.14:1 to a 7:1 differential ratio with a 6.32:1 first gear will give you a ground speed of about 1 7/8 MPH @ 1000 RPM. The C-4 with 5.14:1 gears and a chain drive 3:1 reduction will give you about 2 MPH in low @ 1000 RPM and a 4:1 reduction will give a good 1.5 MPH @ 1000 RPM.
As others have mentioned, you will probably need a second transmission or a chain drive reduction to get a decent enough ground speed.
Nice looking work! :)
Thanks guys for all of the info. I did originally have a 4sp in it from a pinto but i deceided to go with the auto for ease of fab. no clutch pedal or linkage. I think it is from a 76 pinto but not sure. maybe i will put that back in. i have already remade the tranny mount once whats one more time.
   / HOMEMADE TRACTOR START #16
Another thought to throw in here, if you could luck into a transmission with the PTO option from a 1 - 1.5 ton truck, that could be useful for a hydraulic pump power source maybe. Or to power something else.
Dave.
Dave you guys are killing me with all of these ideas!!! :) I already have a bunch of stuff running through my little brain now there is another.....lol
Thanks Crank
   / HOMEMADE TRACTOR START #18
Nice job on the headers. I've always wanted to practice building a set, that looks like a great application to learn on.
Have you thought about wheelie bars yet? :cool:
   / HOMEMADE TRACTOR START #19
Thanks Crank
I should be thanking you, hanging around on TBN is a lot more fun than painting doors - which is what I am supposed to be doing :eek:
Dave.
   / HOMEMADE TRACTOR START #20
I'm surprised no one has commented on your hood yet. It looks nice. In my opinion, the hardest thing about making a home-made tractor is making it actually look like a tractor. So far you're doing great.
You're going to need different tires, but I'm guessing that was already in the plan.
2022 Trail Runner Travel Trailer (A50121)
2022 Trail Runner...
2003 John Deere 2210 Compact Tractor (RUNS) (A50774)
2003 John Deere...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
