Guess what this threads about!!!
   / Guess what this threads about!!! #1
Bama67
Enterprise AL
Branson 5520H
Guess what this threads about? Grapples!
I know there are alot of grapple threads, but most of what is talked about is about how the 48" wide can do the work of the wider ones, and in most cases is better because it focuses the pressure to a smaller area, for uprooting trees and such.
My question is, how narrow is TO narrow?
I have 50 acres of woods, and am working on clearing a long drive, and am starting off with a small area for a camp/eventual home site. I know there is other equipment better suited to this task, but that is not an option. I don't have the money, but I do have a nice 40hp tractor with a loader. And I enjoy hauling it over there and working on my days off, I am in no hurry, and so far I have made great progress with just the bucket. But I need me a grapple.
The two I am looking at is the Markham light duty grapple 48", that many on here have had good luck with.
The other is the Mini gator Extreme, which is 30" wide, and is much more robust/stouter design.
They cost the same, and the weight should be about the same.
I am sure the Gator will be better at uprooting the trees, which is what I will be using it the most for. But at 30" if I have to move brush piles and such, would it be able to get a good enough bite? What about moving old bales of hay? I am thinking it would be fine for moving trees with trunks, but I am not sure about pulling out brush and similar things.
What do you more experianced guys think?
   / Guess what this threads about!!! #2
One thing that doesn't get talked about much with grapples is how well you can see what you're doing. My ground here is not flat, so the tractor and the grapple are often on different planes. I like being able to see the outer edge of the grapple on either side for picking up brush, objects, etc. My tractor is not one of the newer style with improved forward visibility, curved loader arms, etc. So I got a 5' grapple, also partly because my Ford quick-attach is quite wide to start with.
As far as having two clamp arms (mine does) it's helpful for big piles, and I can see what they're doing better, but I think you'd have more control with one. Get a grapple and find out - they're very useful.
Jim
   / Guess what this threads about!!! #3
I have a Kioti DK45SC that I have been using this fall to push over spruce and apple trees in an old, overgrown field. The trees range from maybe an inch in diameter to eight or ten inches (and 20+ ft high). With only minor bending of the FEL bucket edge, I have managed to down a whole lot of spruces. Like you, I have wondered what the best choice is for cleaning up all this mess will be.
I think the 48" width grapple rake is probably as narrow as I would go since I will be using it more often to collect, move and pile debris than to excavate/uproot trees and brush.
Having said that, I now wonder if my intended use favours a design like the Markham (which is more L-shaped) over the root rake design of, say, Horst Welding (which is more like a bulldozer blade in profile).
I'd love to hear from experienced users the pros and cons of different widths, steel types, tine spacing, rake profile and grapple setup.
I don't mean to hijack your thread, but maybe expand its scope a bit.
BOB
BOB
I don't mind, I could always use a little more grapple info. But I have done numerous searches on here, and have read alot about the different steel types, spacing etc, I just never could find anything on the topic of the really narrow grapple, like the 30" wide markham Mini gator extreme.
But so far, unless convinced otherwise I am leaning to the mini gator, mainly because my enitre property is heavily wooded. There is not much brush, mainly just trees, so the only brush piles I would have to move would be the trees I have already pushed down. But sometimes I move old bales of hay and whatnot, I just wonder if it would give me enough bit to do that.
And I am with you about bulldozing trees. My tractor is your tractors smaller step-brother, Bobcat CT440. lol. I couldn't believe the size trees I am able to push over, then pull up if I just take my time at work at it. I wouldn't be able to if these trees were in the regular Alabama red clay, but I am deep in the woods, and that old loose dark soil, and shallow roots, I am able to push up some pretty good size trees. I can do this well enough with the bucket edge, but once the trees are on the ground, I can't move them around unless I push a little, back up, push, back up, push some more. I need a grapple to just grab them and go. But with the grapple, it would also be easier just to pop them out of the ground by the roots, and keep on truckin'.
And now that I have been looking at them alot, I WANT ONE BAD!
Okay, couldn't find nothing here, but did a search on google and found a thread about the mini gator vs 48" light duty.
I think I am leaning now to the 48" light duty with extra spacer tines on the bottom. I feel like I will get a wider range of use from it. And I also figured out it opens several inches wider than the gator, and that could make all the difference with some items. Still on the fence though.
   / Guess what this threads about!!! #6
I'd pretty well decided that 48" was a good width for me, but I wasn't sure if the extended tooth design on the Markham would work as well for popping up roots vs. the more dozer-blade profile of some other makes. I was concerned about both leverage and durability if I used the unit to actually uproot/push over trees rather than just grabbing them to dispose of.
BOB
   / Guess what this threads about!!! #7
Mini Gator vs 48 inch grapple for dealing mostly with trees...good question.
I don't have any experience with the mini gator but I know what it is and have seen the photos. I do have a lot of experience using a 48 inch grapple on essentially the same tractor you are using (mine is the Kioti version with the KL401 loader). With brush the grapple wins though the mini gator could certainly manage brush. The issue with trees is whether or not the mini gator really has a significant advantage. I take out trees quite frequently though my major battle is with brush. When I need to take out a tree I use the grapple elevated to about 9 feet or so to push on the tree until I have exposed some roots then I back off and use the grapple to get under the roots. I can do that with the 48 inch root grapple without much difficulty so I don't know how much more efficient a mini gator would be. I think the biggest factor is the weight of the tractor (for pushing) and the strength of the loader (for uprooting). I would think the shape and size of the grapple would be less of an issue especially when comparing a 30 inch to a 48 inch grapple. Both would have a big advantage over a six foot grapple.
The mini gator is based on the trapazoidal shaped stump bucket and those buckets seem to get mixed reviews. They do allow you to focus a lot of power in a small area but they are pretty much limited to that one task.
I don't think there is a clear answer to your question. If I had to do it again I would definitely go with the grapple as it is far more versatile but I cannot say that it would do a better job of the task you outline in your original post.
   / Guess what this threads about!!! #8
No experience here but it would seem that 30" would be getting pretty close to total space between FEL arms on a 40 hp tractor. I believe I would like a little more protection from branches and such that the 48" grapple would offer.
MarkV
I have made up my mind to get he 48" grapple with the extra spacers. Now hopefully my hydraulic remotes will be in sometime this century so I can order it.
   / Guess what this threads about!!! #10
Looking at the photos (and skimpy info) on the Markham site, I can't really tell how the Gator/Mini-gatror is different from the standard Markham root grapple. Can someone enlighten me?
From all the reading I've done, I'm probably going to order a 66" standard duty Markham unit with extra spacers. This is primarily for a JD 325 skid steer but I might also use it on my Kubota M5040 tractor. I know some have suggested that narrower is better, but I do want to be able to clear a path for the skid which is 72" wide (standard bucket is 78").
I've looked for more specific skid steer/grapple info on the heavy equipment sites but there is not much discussion of specifics on those sites.
Ken
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2019 Kenworth T680 Tandem Axle Road Tractor (A47384)
2019 Kenworth T680...
New Holland 900 Chopper (A50774)
New Holland 900...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
