PTO speed stability
   / PTO speed stability #11
You had better be home and awake when the power goes out.
E/S
E/S
:confused:
In a perfect world I would call my local Kohler Power Systems dealer and hand him a check for $8k. Problem solved. Unfortunatly I live in the world of compromise.
   / PTO speed stability #13
:confused:
Me too, that is why I bought a used 15 kw Kohler unit.
E/S
   / PTO speed stability #15
why do you think they even make pto run gensets???
if yer tractor is brand new.. it's governor function will be good and crisp, and it's engine fresh.
since the 2hp per kw is only a rule of thumb anyway.. and a new machine is very likely to have hp in excess of it's actual rating.. you may very well be able to realize the full 10kw.. though perhaps not any surge value. no biggie.. it's a good match.
I have a northern 12.5k pto genset I have run it on a variety of my tractors from a 52 ford 8n, a 55 ford 660 and a 75 ford 5000 all ran it fine. the 660 ran it the longest .. ie.. daily for weeks till power got ran out tot he back of my farm.. it handled a well pump cycling on and off as well as power tools while I was fencing and watering the property.. the old gov onthe 660 held her inthe green zone on the well cycles with no issues... needle did float a lilinthe green.. but stayed in the green.
2k+ for a 10kw head? YIKES.. I'm in the wrong business.. mine cost me 999$.. and may be up to ? 1100 or 1200$ by now.
Shop around as the song says..
soundguy
Hello,
I am on the verge of buying a PTO driven 10KW IMD generator. It will be driven by my brand new :cool: MF GC2410. This tractor has a PTO rating of 18.7 hp. I realize a 10kw generator is slightly over sized for this hp and I will no be able to get the full 10kw. I'm guessing I can expect somewhere around 9.3kw. My concern is with the speed stability of the tractor driving the generator. Can I expect the tractor to hold PTO speed rpm closely enough to be able to use this setup for backup emergency power for the house?
I am looking to be able to have motors such as a deep well pump, oil furnace blower, refrigerator and some lights cycle without problems. The loads will be balanced across the generator legs as best as possible.
Does the speed governor on the MF hold speed closely enough to 540 so I will get a stable 60Hz from the generator?
If the tractor can hold rpm close enough with cycling loads (within its power limits) then I am ready to make this $2k+ investment. If the tractor rpm is going to sag and surge with every change in load then I have to look elsewhere for backup power.
Is my expectation to high for this little tractor?
soundguy
Thanks for the info soundguy. I was concerned it would only be suitable for short term like running a welder out in the woods. With the info you and Brin have provided I have no reason to be concerned. I am looking at the IMD unit. They are a sponsor of this site. I was a little misleading on the $2k number. The unit itself is about $1200 directly from IMD. The auto voltage regulation adds another $150, the 3pt hitch mount is another $280, I need a pto shaft which added another $180. That gets me to $1800 plus another $150 for shipping. I will also need to install a 200amp transfer switch, outlet, cordset and some conduit and wire. When all is said and done I'm looking at $2700. I could save $150 buy not getting the auto voltage reg, but that seems silly when I'm spending this much already.
I have found a couple alternatives to the IMD. Just looking at the gen head itself, Winco makes a nice unit, but it is quite a bit more expensive at $2k for the 11kw. The smallest Onan I found is 15kw and over $3k. There is a 12kw GeneratorJoe that is similar price to the IMD, but I can't find much about who actually makes the GeneratorJoe unit. The IMD seems a little nicer.
I'm not interested in the Harbor Freight unit.
Are there any other brands I should consider?
Thanks!
   / PTO speed stability #17
I didn't mention harbor freight.. I mentioned northern tools.
the active regulation is a great choice.. though i seem to be getting along fine with passive.. if it's a semi-dedicated house unit.. you can't 'loose' by going active.
180$ for a po shaft is about 80$ too much.. and 180$ for a 3pt carry-all is about 100$ too much.. nboth of those are local TSC items that you can pickup and avoid the shipping costs. Chewck yer local tractor dealers as well.. I see winco gensets on towable trailers or box skids at my local NH dealer.. you never know what yer local dealers may ( may not ) have.
yer tractor should be able to make pto rated power for more or less continous duration at least up to it's fuel capacity. Lord knows I've mowed dark to dark with my tractors making pto power all day only stopping to take a leak and fuel the tractor.. etc.. that's what they are for... not like a car engine that canmake top hp for a few seconds, then run at just above idle the rest of the day while in overdrive...
soundguy
   / PTO speed stability #18
A couple of years ago I built a PTO driven 12000 watt generator I purchased from Northern Tool. I'm running it off a older Kubota L245DT tractor. I now consider it only as a backup for my standalone 12000 watt generator. The standalone is powered by a BS 24HP, and the PTO is powered by 23HP at the PTO. The standalone will tolerate different loads much, much, better than the PTO one. To me, the only advantage the PTO generator has over the standalone one is in fuel economy. That would be outweighed if at any time during the emergency you needed to use your tractor. Hope this helps. Pete
   / PTO speed stability #19
that's easy.. just have 2 tractors! The tractor will likely start when needed vs the lawnmower engine.. :)
I want my backup power to be run by an engine that costs a few thousand bucks.. not by one that has 'realatives' that mow grass :)
soundguy
Oh yeah, I forgot to mention Northern. Years ago the Northstar generators were made in the USA. They don't advertise that anymore. A electrician I work with has told me they are not the quality they once were. I don't know it that is true or not. In any case it's 13kw, $1400 with cap voltage reg. They offer a mounting plate for $50 but then I have to fab up a mount to get it into a universal carry-all like soundguy suggested. That option seems like more work for similar money, rather than the generator manufactor 3pt hitch already ready fabbed up to take the specific gen head.
I really would prefer to buy somthing made here. (Or at least assembled here). The US gen heads I have found so far are IMD, Winco, and Onan. Are there any others?
BTW, Good tip about calling local tractor dealers to see if they have anything sitting around they want to move. I'll do that tomorrow.
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
2025 Mower King ECSSTR072 (A50123)
2025 Mower King...
UNUSED RAYTREE RMBD72S-72' DRUM MULCHER (A51248)
UNUSED RAYTREE...
2023 JOHN DEERE 8R340 LOT NUMBER 205 (A53084)
2023 JOHN DEERE...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
