Well said! Why buy a bazooka when most of your hunting will be small game?
Because sometimes you'll NEED the bazooka, and you won't have it.
Your decision comes down to what you're going to use it for. Going back to your original post, I understand that your WIFE is going to use it to help blow snow, correct? If that's the case, consider 2 things;
I have the 2210 (same tractor different year), and my wife and daughters have NO trouble using it. We don't live on a farm, just a large lot, so I'd say they are much less equipment-savvy than your wife is, so as far as her being able to use it, no problem.
When blowing snow, know that I've had a 400-series garden tractor and a 4100 compact utility, which I traded in for my 2210 (moved, thought the 4100 was too much, regret it...long story!). I had these tractors in North Dakota, so I got a LOT of use out of them for snow-blowing. When trying to blow snow on a windy day, or if the snow is wet and heavy, or it's icy, you're going to want the larger tractor. Period.
HOWEVER, if you're truly going to use this to mow, consider the fact that the 4ws (749) tractor has an internal unmowed radius of 6", while the 2305 (with a 62" mower deck) has more like 20". That doesn't seem like much, but I'm here to tell you it adds a lot of time to your job. I've never had a problem with the weight of my 2210 in terms of hurting my lawn, even when wet.
So, what will you use the tractor most for? And remember, that few times that you could use a larger machine for a job (the bazooka) and don't have it will make you wish you'd picked the larger tractor. My grandfather always used to say; "you can never have too much horsepower."
Bottom line is I think you'll be happy with either tractor, but each will make you wish you'd picked the other at some times, depending on what job you're doing at the time. If you REALLY want to score some points, I'd suggest you let your WIFE pick between the two; then she'll be more likely to use it, you'll be a major stud in her eyes, and you can always blame her for picking the "wrong" tractor if you end up with a job that is harder to do with the one she chose!!
