Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,001
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I don't need to replace mine (at least, yet). I'm merely curious.
As I look at my well head, I contemplate the mechanics. My well is maybe 300+ feet deep, my pump itself is at say, 200' and the static water level is at say... 100'.
There is going to be a cable AND some kind of tubing that is attached to the pump.
To start lifting these things out of my 6" casing, you are going to need to twist and bend the wire and more interestingly.... the water pipe.
To make matters even more complicated, again, as I look at my own system, it seems the electricity goes into the well via a piece of conduit, pretty much at the top of the well.
The water itself, seems to come out beneath grade. Does it come through the well casing at 12" below grade...24" below grade?
For conversations, let's not worry about that TOO much and simply say it's 12" (any deeper only complicates my thinking process)
So, as I vision it, you have a pipe that would be about 200' long. It's connected at one end to the pump, goes up the well to this location where it's going to make a 90 degree bend to go through the casing (underground) and over to my house.
How on earth do you pull the water pipe up such that you can create a tight enough bend in it to pull it past itself (at the 12" deep mark)
Again, mine is fine, this is simply me being curious about things I am probably better off not being curious about.
